4.3 v/8
Old Sep 30, 2001 | 12:12 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
4.3 v/8
will the crank from the 2nd gen 4.3(caprice) fit into the 1st gen block?if i was to make a 327 using an 88 block and the above mentioned crank would it physically bolt togeth?er
87 trans am,gm crate 350(4 bolt mains 10to1),L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,gutted airbox,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ed wright's fastchip,relocated iat sensor,160 fan switch&t-stat,tb bypass,accel supercoil,cap& rotor,slp 3in. catbcak,a/c delete.
SHE IS GONE BUT I KNOW THE GUY WILL GIVE HER A GOOD HOME.
best e/t:
3653lbs./full tank+ driver.
14.10@96.53mph 2.01 60'
Old Sep 30, 2001 | 01:08 PM
Tas's Avatar
Tas
that crank and a one piece rear main seal 350 block will get you a 302 not a 327. Unless you put it in a 400 block. I don't know how you would get it in a 400 though. Rear seal adapter?? It would be a waste of a 400 at any rate.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
To be installed eventually far far far into the future: Yours if the price is right and I don't have to ship :
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Got Beach?
Old Sep 30, 2001 | 04:56 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
A 4.3 is a 6 banger so no it wouldent fit. Now if you were talking 327 crank with a 350 block that can be done.
SSC
Old Sep 30, 2001 | 05:25 PM
Tas's Avatar
Tas
SSC there was a 4.3L version of the LT1 put in the caprice. It's called a L99. A small v8 would run smoother than almost any v6(especialy an American one) so they gave the old folks the L99 in their Caprices.
-Tas
'89 Formula WS-6
Super GRK_Taz World
F-Body Dual Exaust
AOL IM: superGRtaz
Got Beach?
Old Sep 30, 2001 | 09:29 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
<font face="Verdana, Arial" size="2">Originally posted by Tas:
</font>
Huh I never heard of it. I guess I'll do some poking about and see what I can find.
Thanks for the info Tas
SSC
southerndude_31
Jan 13, 2002 10:05 AM
GreenMachine92rs
Aug 2, 2001 09:48 PM
gemmefire
Mar 16, 2001 06:32 PM
gemmefire
Mar 13, 2001 08:22 PM
PONTIMANIAC 90
Dec 20, 2000 07:56 AM
