Is it true ?
Old Feb 10, 2010 | 01:41 PM
Steven20063's Avatar
Is it true ?
A person I know who happens to be a pretty respected, ASE cert. mechanic said that a 350 sbc with just votech head, and a cam, on stock internals, can produce and maintain 350 horsepower . Is it true ?
Old Feb 10, 2010 | 01:46 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Is it true ?
Easily, 1 HP per cu-in is nothing, you don't even need vortec heads for that. The SBC was the first production engine to do that back in the 50s.
Old Feb 10, 2010 | 02:21 PM
Stephen's Avatar
Car: 87 GTA
Re: Is it true ?
You don't even need Vortech heads to do that.
Old Feb 10, 2010 | 02:37 PM
elano's Avatar
Car: 86 IROC-Z, 82 z28
Engine: 383 Stroker
Transmission: TH-350
Axle/Gears: 3.73 Torsen, 4.56 Auburn
Re: Is it true ?
Yea, 1hp per ci is pretty good.
Old Feb 10, 2010 | 02:56 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Re: Is it true ?
vortec heads can get you around 400-450 horses if you spend $150 on them. They cut the valve guides and use thicker springs to run a hotter cam.
Old Feb 10, 2010 | 11:38 PM
0pyders's Avatar
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
Re: Is it true ?
but how come cars like the 3rd gens didn't have that much. like my 86 firebird has like 160 hp with a 305 engine. is it the exaust;headers that take it away?
Old Feb 10, 2010 | 11:46 PM
Stephen's Avatar
Car: 87 GTA
Re: Is it true ?
Because the 80s was the beginning of EFI. The engineers were still working on balancing horsepower, fuel economy & emissions requirements.
At the same time..... They were working on airflow efficiency with EFI & getting the injectors to atomize the fuel good.
Old Feb 11, 2010 | 01:15 AM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: Is it true ?
and you may be looking at two different power numbers.....remember you lose a lot of ponies from drivetrain loss. Like for example if your motor put out 500 horses on an engine dyno, then you tested the same motor in a car on a vehicle wheel dyno, you might only have 400 horses left.
Old Feb 11, 2010 | 01:40 AM
elano's Avatar
Engine: 383 Stroker
Re: Is it true ?
350 rwhp is no joke, that would take over 400 flywheel hp and not something I would say is too easy for a 350. It takes the right parts.
Old Feb 11, 2010 | 02:07 AM
ShMaCk2004's Avatar
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
Re: Is it true ?
100hp per liter is a bit harder to accomplish N/A but possible still
okfoz
Oct 13, 2015 02:19 PM
mattcanty
Oct 12, 2015 11:08 AM
91 SrS
Oct 7, 2015 04:32 PM
paul_huryk
Oct 1, 2015 04:27 PM
Djmathis123
Sep 8, 2015 08:42 PM
