350 tpi to 400 carb
Old Oct 26, 2001 | 04:18 PM
FORMULAFREAK's Avatar
350 tpi to 400 carb
I have an 89 Formula with a 350 tpi and want to know if a Pontiac 400 bored 30 over from an old Lemans would fit in. The engine has been sitting in my garage for years now and needs to have some fresh power producing parts in it if you know what I mean muhahahah POWER! The old parts wont just cut it even though they are high quality parts from when my brother first bored it and hopped it up. Will I need to modify a lot from what I know isnt a 400 the same size as the stock 350 just bored out bigger though right? Also what type of other mods will I need electrical, rearend, trans, suspension, are these going to need special attention along with other components? ANY HELP WOULD BE GREAT THANKS.
ASA
"SUCKIN GAS AND HAULIN *** !"
Old Oct 26, 2001 | 05:11 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The Pontiac 350 and 400 were like each other, but completely different than the SBC's put in our 3rd gens. It can and has been done, but you'll probably be disappointed with the results after a lot of hard fabrication work (and you'll need a different tranny) to put in a heavier and most likely less powerful engine.
You'd be a lot better off making a 383 out of your current 350.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 CC system w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker 2055 headers, 3" Catco cat & 3" catback, restalled TC, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
camaro71633
Sep 1, 2015 10:24 AM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
