Will 89 tpi parts fit a 86tpi setup
Old Feb 18, 2010 | 11:59 AM
intmdatr3's Avatar
Car: Monte Carlo SS
Engine: 305 W/TPI
Transmission: 2004r
Axle/Gears: 3:73 Posi
I was given a 89 tpi setup and I am running 86 setup. It has slp runners will they fit my current setup.
Old Feb 18, 2010 | 01:31 PM
The Devastator's Avatar
Car: 1992 Camaro RS
Engine: 8.0:1 454/Mild Hyd roller/Accel DFI
Transmission: WC T5
Axle/Gears: Stock 1992 open 7.5" 2.73 ratio
Re: Will 89 tpi parts fit a 86tpi setup
So far as I know there are two types of TPI...... 85-89 and 90-92. IIRC all the parts from the same vintage manifolds will interchange. Besides that the only difference is that corvettes all used one fuel rail and camaros/firebirds all used another. Corvette fuel rails terminate on the passenger side and camaro firebird fuel rails terminate on the driver side.
Old Feb 18, 2010 | 03:07 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The runners should fit.
'89 didn't have the cold start injector like the '85-'88 MAF systems did. But that's in the plenum.
Old Feb 18, 2010 | 04:25 PM
Stangski09's Avatar
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
If you have an 86 setup, 89-92 runners will work, but youll need to plug your fuel rail where the 9th injector comes out of. And you will need an 89-92 plenum as well.
Is this all correct?
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
1nastygta
Aug 8, 2015 07:38 PM
