RPM air gap
Old Oct 29, 2001 | 09:43 AM
quest for 12sec..92RS's Avatar
RPM air gap
Has anyone tried to put an RPM air gap intake under the stock hood? I was just wondering if thats possible or if anyone had done it. And if not what amount of clearance was needed more than the stock hood provided?
Old Oct 29, 2001 | 09:47 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
It fits with room to spare when the proper
drop base air cleaner is used Z28 Corvette
style.
Old Oct 29, 2001 | 08:30 PM
Fbird88's Avatar
Car: 1988 Firebird
Engine: GM Performance Parts 350 HO
Axle/Gears: :(
<font face="Verdana, Arial" size="2">Originally posted by F-BIRD'88:
style.
</font>
I have it and it won't fit under my hood. I have a 600 dp carb and used a 14 X 3 K&N air cleaner with a 1 1/4" drop base. The top of the filter is dead even with air horn on the carb. I even cut the hood bracing and wing nut, but my hood still won't close. If you know how to get it to fit, I'd REALLY like to know. What's a Z28 Corvette style air cleaner?
Old Oct 29, 2001 | 08:50 PM
F-BIRD'88's Avatar
The air filter is from a '67-69 427 corvette
or '67-'69 302 Z28 Camaro. It uses the stock 14x3" filter. Some of the aftermarket air cleaner bases don't drop as nicely around the carb as the GM base does. There is more
than enough room even with a 1/2 inch nitrous plate. I have this setup on my Third gen firebird now.
Old Oct 29, 2001 | 09:41 PM
Fbird88's Avatar
Car: 1988 Firebird
Axle/Gears: :(
I guess my carb is too tall. If I get a shorter filter, the air horn won't clear. The hood almost closes though.
[This message has been edited by Fbird88 (edited October 29, 2001).]
Old Oct 29, 2001 | 10:54 PM
JPrevost's Avatar
Car: 91 Red Sled
I'm also having problems with hood clearance and my RPM intake manifold. I have a 1" holley adaptor to TBI and it doesn't fit. I'm thinking about grinding the adaptor plate on an angle because only the front lip is hitting. The performer fits but it's because it's front carb surface is so much lower than the rpm. I have to figure this out because I don't like using the proflow piece of crap.
, Jon (350 TBI!)
91 Red My website
Old Oct 30, 2001 | 04:59 PM
hot89camaro's Avatar
it will fit with the recessed air cleaner, and about a 1" filter element. However, i used this setup, and the hp/torque you gain with the intake is compromised by the air filter needed. This is not worth the money unless you run the intake with the proper air cleaner. It is essentially an RPM manifold except has a "valley pan" to isolate the runners from the hot oil splashing up underneath! before purchasing this intake, get a spacer for your tbi/carb which isolates heat, and you will do about the same thing for 20 bucks insteal of 200!
89'rs
400 Small Block
10.2:1 AFR Heads
427 hp, 454 ft/lbs
eightsixseven
Dec 16, 2024 01:50 PM
specialized
Jun 18, 2022 09:26 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
TreDeClaw
Aug 14, 2015 06:58 PM
