motor swap
motor swap
i have just bought a rebuilt 350 short block(bored and stroked with comp cam). now i want to put the best combo of intake, heads, throttle body, headers ect...on it. does any body know a good combo that would give me MUCHO horse power but still pass smog laws in CA. and if they dont pass smog does any body know a good trick to pass smog?
Transmission: 4L80E/4L80E
To really answer your questions, we'd need to know more about the cam, piston type (dished, flat top, cast, forged, hypereutectic, etc.), induction type (TPI, TBI, CC carb, etc.), year model of your car, exhaust system, and intended usage (assume street, because you mention emissions).
Check out the magazine articles on this board for the two written by Steve Green with titles to the effect of "Stroke in the Desert". He built a 383 with CC carb and passed Las Vegas emissions with it. He went with 3.73 gears & posi in his otherwise stock 10-bolt.
World Products Sportsman II heads are a less expensive alternative to the heads he used.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2200 stall TC. Ported World 305 heads, Crane PowerMax cam. ZZ4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster. 2.93 limited slip, Spohn SFCs. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
I live in california and I too have to worry about the smog laws. Ive been fixing up my iroc and looking at this stuff extensively for a while now. There are a ton of factors that go into deciding whats the best combo to use, but heres the combo that I am going to try to go with:
Heads- AFR190's
Intake-TPIS Big mouth base and Accel SuperRam
TB- Any good 52mm TB with airfoil
Headers-SLP 13/4 to go with good catback
I would like to go with a miniram, but I have to stay legal so the superram seems to be the next best choice. You will also need to have the cam to match , but this combo should work ok with your stock gears.
I hope this helps.
Mike
Heads- AFR190's
I hope this helps.
Mike
