Block and Head ?
Old Nov 14, 2001 | 06:29 PM
Ezey Go's Avatar
Block and Head ?
I just got a 350 block out if a 78 camaro and I was wandering if a set of 87 and later heads would work with it?Thanks for any replies.
Old Nov 14, 2001 | 06:53 PM
SoCo80p's Avatar
they will fit but you have to get a specal intake manifold, edelbrock sells them.
Old Nov 14, 2001 | 07:13 PM
quest for 12sec..92RS's Avatar
Yeah, they will work just fine, and you can use most any intake. The center bolt holes are different from 86 and below, but all it takes is a little drilling to make them fit. And you won't have to pay the big dollars for a late model intake.
Old Nov 14, 2001 | 07:54 PM
SoCo80p's Avatar
the intake bolt holes are COMPLETELY diffrent on the 87 and up heads, you have to get the special intake from edelbrock,
Old Nov 14, 2001 | 09:03 PM
Guest
Guest
Posts: n/a
<font face="Verdana, Arial" size="2">Originally posted by TempesT68:
the intake bolt holes are COMPLETELY diffrent on the 87 and up heads, you have to get the special intake from edelbrock, </font>
Youre mistaken, its a minor difference in the 4 center intake bolts, the "old" style is 90 degrees, the "new" is 72 degrees. Minor machining/drilling required.
Old Nov 14, 2001 | 09:36 PM
Tim Hunsinger's Avatar
Car: 91 RS,
Engine: 406ci
Axle/Gears: 2.77 9 bolt
true, I have a an old style Edelbrock intake on my 1988 350 heads. Works great.
Old Nov 14, 2001 | 11:05 PM
Ragin'87's Avatar
all you need to do is wallow-out the center holes some, and use a washer. an early intake will fit the late-model heads. I don't typically do that, but I have, and it worked just fine. In fact I've gone backwards and put a late-model intake on earlier heads. I was putting the 350 into my 87, and this guy broke a chunk off his Edelbrock, and NEEDED(read had to be across Texas the next day) a Q-jet intake. We pulled the intake off my dead LG4, took a die grinder to the center holes, and bolted that POS onto his 68 Chevelle, worked like a charm, and I got $75 for an intake that I wouldn't take for free!(gesture of gratitude I suppose, I didn't ask for any money.)
Anthony
previous ride: 87 Camaro LT
350, A4.Comp Cams 268H, Edelbrock Preformer intake, Hedman Headers and y-pipe, gutted cat, No AIR/smog pump. 14x3" Open element K&N, Q-jet w/ D hanger and DA rods, adjusted AV spring tension and quick can.
Current ride: 1992 Camaro RS, K&N, Flowmaster, 305, T5, Black, T-tops, 84k miles.
Old Nov 15, 2001 | 12:01 AM
SoCo80p's Avatar
yeah but im just stuck on doing things the right way
Jake_92RS
Jan 28, 2020 10:37 PM
MoJoe
Sep 24, 2015 09:12 PM
Ducati900ss
Sep 2, 2015 09:05 AM
gixxer92
Sep 1, 2015 04:32 PM
lakeffect2
Aug 23, 2015 08:44 AM
