how hard to swap this
Old Nov 22, 2001 | 05:08 PM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
my car has the lg4. my uncle has a 77 blazer with a 4 bbl 350. it seems to run pretty good. he's trying to get 500 for the truck, but i could probably get the engine from him for less than that. how hard would it be to do this swap?
87 Camaro LT
bone stock 305 w/ 700r4 0-60: 3 minutes
mods to come:
ground effects
93 camaro seats
99 camaro center console
91 z28 rims
white 145mph iroc gauges
Old Nov 22, 2001 | 06:37 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Not too hard. A couple of things you'll come up against are:
The 2-piece rear main seal, since the truck likely has a 168-tooth flex plate, your '87 flexplate won't fit - get a 153-tooth piece for an '82-85 Camaro.
The dipstick will be on the driver's side, and won't clear stock exhaust manifolds. Headers will fix that, though.
Don't expect this engine to be a barn burner. Trucks got low compression and small valve heads coupled with a cam designed for torque. That isn't hard to fix with pistons, aftermarket heads and cam kit.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2300 stall TC. Ported World 305 heads, Crane PowerMax 2050 cam. ZZ3/4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster 80. 2.93 limited slip. Spohn SFCs waiting to be installed. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Nov 22, 2001 | 08:28 PM
427camaro's Avatar
Car: 05 Nissan Xterra
Engine: 4.0L DOHC
Transmission: 5 Speed Auto w/ OD
That's a bad burnout man! I love it! Where'd you get your 1993 Camaro seats and how much?
2.8 Liter V6
No Current Mods
[This message has been edited by 427camaro (edited November 22, 2001).]
Old Nov 22, 2001 | 09:25 PM
Diabolical's Avatar
Engine: 305HO L69
thanks man, i needed new tires so me and a friend went to the dead end circle of his road, and i made sure that i got the most out of the tires before i changed them. i wanted to keep going with it, but the smoke started to seep into the car, i wasn't a fan of that.
the 93 seats, i got them from a local junkyard in connecticut, they're just about mint, only a couple small stains, i got the front and rears for $150.
87 Camaro LT
mods to come:
ground effects
93 camaro seats
91 z28 rims
Old Nov 26, 2001 | 06:35 PM
mikeage2's Avatar
yeah and make sure theres 3 holes fo rthe starter....when yo uput on that smaller flywheel the starter will be a inch to far away from the starter.if it dosent have the third and closes hole,youll have to either:
1.buy a expensove gear reduction starter or
2.do like i did and get a camaro starter,bolt on the one bolt that is there,and line up the starter housing on each sode evenly between tha housing and the end of the block where the tranny meets.after its lined up,mark the hole with a long punch.then take starter off,drill and tap the hole...only took me like 5 minuites.do yourself a favor and but a new tap and drill bit so i tgets done easy and fast.
mike
Old Nov 27, 2001 | 03:32 PM
Z03Z28's Avatar
Car: 92Z28,98LegacyGT,ZX9R,91 Z28,02 Z71
Engine: 350,307,2.5,900cc,5.0
Transmission: 700r4,4spd auto,700r4,4L80
Axle/Gears: 323,?,323,?,373
Was it a pita putting a 99 console in your car?
Old Nov 27, 2001 | 05:30 PM
Diabolical's Avatar
Engine: 305HO L69
haven't found that out yet, i have the console, i'm just waiting till i get the rest of my stereo stuff. i figure it will be easiest to do it all at once. once i'm finished, i'll be posting pics on the body and interior forum
87 Camaro LT
mods to come:
ground effects
93 camaro seats
91 z28 rims
bamaboy0323
Sep 3, 2015 06:07 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
86White_T/A305
Aug 17, 2015 12:16 AM
cstrobel65
Aug 15, 2015 10:19 AM
