What would a v6 need to have a 305 put into it
Old Nov 29, 2001 | 12:36 AM
Trent257's Avatar
computer changes, what else, tranny
Trent
---Car---
89 Firebird/305 L03 TBI A4/t-tops
Open Element Edelbrock Aircleaner w/ K&N air filter/Summit Chrome Valve Covers
Edelbrock TES headers 3" out/flowmaster American thunder 3" exaust/Catco cat
---Stero---
Pioneer DEH-P730 Premium
Infinity 2way 4652 4x6's/Pioneer 4way ts-a6985 6x9's
profile cl640 110x4
Old Nov 29, 2001 | 08:28 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
That, and complete engine harness, all hoses, cables (throttle, TV, cruise), AC stuff, accessory brackets (alternator, PS, AC, etc.), engine mounts, fuel lines, radiator, and of course water and fuel pumps. Don't forget front springs, sway bar.
Basically anything that goes on the engine or between it and the chassis, and those things affected by the extra weight.
It's typically more economical to sell the V6 car and buy a factory V8 car.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2300 stall TC. Ported World 305 heads, Crane PowerMax 2050 cam. ZZ3/4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster 80. 2.93 limited slip. Spohn SFCs waiting to be installed. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Nov 29, 2001 | 08:51 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
five7kid is correct : It's typically more economical to sell the V6 car and buy a factory V8 car than swap in a v8 into a v6 car.
if you really want a v8, sell the v6 car & get one with a v8 in it. if you want a more powerful 6, either mod it or put in a 3.4. for more power, mod the 3.4. there are always turbos & superchargers too.
[This message has been edited by Project: 85 2.8 bird (edited November 29, 2001).]
Old Dec 2, 2001 | 11:57 PM
HamsterOnaMission's Avatar
What kind of structure issues would putting a larger engine bring up for an originally v6 car??? I sold my first rotted out, half bondo POS '83 V6 camaro and picked up an '84 camaro which is in good shape, but had already had a poorly done swap. It went from the V6 to a 350 HO, with no change in anything else ( V6 wiring harness pushed back fuel lines over the top, crap everywhere, nothing hooked up) It was cheap and seemed like a pretty good deal at the time.
I've got the actual engine all set up (rewired, vacuum lines, etc) and ready to go, but what should i look at changing as far as the structure, suspension, and Drivetrain go. Don't suppose i'm lucky enough for it all to be trouble free in the future?
I currently have subframe connectors, springs, strut tower braces, and a rollcage lined up for near future installation. SHould i be thinking 'transmission, rearend, etc' instead?
[This message has been edited by HamsterOnaMission (edited December 02, 2001).]
Old Dec 3, 2001 | 08:39 PM
five7kid's Avatar
The transmission had to be done to get a V8 in there. Check out Pro-Built's page above for ways to make your tranny even better.
You've already got springs. SFC's are a good idea even for V6 cars. Shocks, struts, differential are all the same between the two. Sway bar upgrades couldn't hurt.
Old Dec 21, 2001 | 08:49 PM
crewse04544's Avatar
you don't HAVE to change the tranny to get a v8 in...it just might not hold up to the power is all
jhawkeye
May 25, 2022 06:33 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Leggman1
Aug 6, 2015 04:15 AM
