Will This Motor Fit!
Old Mar 6, 2010 | 11:07 AM
I_R_O_C_Z_2_8's Avatar
Car: 1991 Trans Am GTA
Engine: 350 tpi
So im picking up a block from a 89 trans am...but i noticed the alternator was on the opposite side..but hes just selling me the block with no intake or pullys..my question is will all the stuff i have on mine like water pump alt...etc just bolt right up to this motor? sorry if its a dumb question was just curious thanks.
Old Mar 6, 2010 | 12:29 PM
Engine: 350 tpi
Re: Will This Motor Fit!
Well lets see if i can just get one question answered....Will it matter if the alternator is on the other side in this motor?
Old Mar 6, 2010 | 01:20 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Our '87 Camaro has a '92 Camaro motor. The PO did the work.
IDK if there is a difference in Pontiac & Chevy bracket mount holes on the heads..??..
Alternator can be anywhere, as long as the pulley rotates in the propper direction.
Old Mar 6, 2010 | 01:28 PM
Engine: 350 tpi
well its a chevy block so everything should be good right?
Old Mar 6, 2010 | 01:39 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It's only the bracketry that makes the alternator sit on the other side. If he's not giving you any of that anyway, it doesn't matter.
Old Mar 6, 2010 | 01:49 PM
Engine: 350 tpi
Oh alright sounds good then...thanks alot.
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
evilstuie
Jan 9, 2020 08:29 PM
slade5612
Aug 11, 2015 07:19 PM
