Help!! Whats wrong with it?? Rebuild or New Motor??
Old Dec 11, 2001 | 06:51 PM
Project_1986_TA's Avatar
Car: 1986 Trans Am WS6
Engine: Mild 350 TPI
I need some opinions on what I should do to my 1986 Trans Am 5.0 TPI. My cousin recently sold it to me for $500 and it doesnt run. The only problems it had before was fuell injectors and alternator. My uncle tried installing a new starter but the engine froze and now it wont turn over.
Do you know what could be wrong with it??
Should I have the motor rebuilt or should I get a new motor? 305 or 350??
Wich way would be cheaper?
Please help!!!
Old Dec 11, 2001 | 08:42 PM
Crusader's Avatar
Car: 1988 Firebird Formula
Axle/Gears: 3.45
Not sure what could be wrong with it but as far as rebuild vs. new it depends on what ya want and your connections. My brother's 4 banger Mustang was around $1000 to rebuild. A guy in the Seattle area ran 12's on a $400 wrecking yard motor in a 4th gen Z28.. You might be able to find a 305 fairly cheap if someone around is ditching their's for a bigger motor, crate motor's/speed shop motor's can range from 1200-7000+
Welcome to the site. You should check out the <a href="http://64.146.4.8/phpbb2/index.php">Cascade Crew</a>, great group of 3rd gen nuts in the PNW. http://64.146.4.8/index.htm
Good luck on the project man!
Jess
Cascade Crew - For you Pacific Northwest guys/gals
[This message has been edited by Crusader (edited December 11, 2001).]
Old Dec 12, 2001 | 07:39 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
You can get a L98 350 from Autozone for $800. Just tell them you need a motor for a 92 Z28 5.7L. That will get you running good for the least amount of money. Sure there are better engines than Autozone but not cheaper. A cheap Autozone motor will probably be more cost effective and give more power than fixing the 305.
evilstuie
Jan 9, 2020 08:29 PM
italiano67
Dec 11, 2016 09:21 AM
backtothe80s
Sep 5, 2015 12:39 AM
fbirdroller
Sep 2, 2015 10:27 PM
86White_T/A305
Aug 17, 2015 12:16 AM
