BUILDING A TTA 3.8 V6
Car: 87 Vette
Engine: 355/195AFR/SR/219CAM/1.6
Transmission: TH700R4/Vigilante
Axle/Gears: D44/3.45
well im very interested into swap my old 2.8 carb from my 82 firebird s/e and i was thinkin of a V8 but ive been hearing so good comments about the turbo 3.8v6 ..what will happen if i put on a turbo 3.8 from a Regal or a Grand national???will it perform like the 89TTA closely...will it be better than a V8 ? it will work with my TH 200C tranny???
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
hey i went to the drag strip lastnight and there was a GN there.....that was running 11's!!!!
84TA T-tops L-69 305HO TH-700R4 stock 190hp and 240 ft-lbs.
best E.T. (dont laugh) 15.997 @86.04mph
http://www.geocities.com/K_towngangsta
You need TTA heads (3.0 FWD heads essentially), TTA pistons (deeper dish, the GN pistons and the TTA heads will yield about 9:1 static CR, the GN's and stock TTA's have 8:1, TTA headers and downpipe. Thats about all the TTA specific stuff ya need, GN block, intake, turbo, injectors, intercooler (the TTA cooler is a little different, but the GN cooler will work) will all work, as well as GN tranny and GN rear (8.5 rear instead of a 7.5). That's the meat of the project, good luck
87 GN
89 RS
85 Toyota 4x4
87 GN
89 RS
85 Toyota 4x4
<font face="Verdana, Arial" size="2">Originally posted by TTA:
The GN rearend will NOT bolt in.
</font>
</font>
I'm Positive.
-Mike
89 TTA
PT51, V4, 50s, 3DP, Stock Long Block and Convertor.....
11.25@121 w/1.56 24psi Through the Exhaust on a 16psi launch
1998 LS1 T/A 6-Speed
13.10@106 Factory Stock down to the air in the tires. 296HP/319TQ
-Mike
89 TTA
<font face="Verdana, Arial" size="2">You need TTA heads (3.0 FWD heads essentially), TTA pistons (deeper dish, the GN pistons and the TTA heads will yield about 9:1 static CR, the GN's and stock TTA's have 8:1, TTA headers and downpipe. Thats about all the TTA specific stuff ya need, GN block, intake, turbo, injectors, intercooler (the TTA cooler is a little different, but the GN cooler will work) will all work, as well as GN tranny and GN rear (8.5 rear instead of a 7.5). </font>
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Soon to be installed:
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
TTA has the Aussi 9 Bolt and is STRONG. I see them holding up to runnin 11 sec 1/4s
89 Trans Am Turbo 3.8L All stock 43,000 miles #1053 of 1555
Past Thirdgen:
86 Trans Am w/ built 355TPI with SLP goodies and too much other stuff to List. One sweet *** car, wish I would have had a good enough Job to pay insurance on three cars so I could keep it, but for a 89 Turbo Trans Am w/ Low miles, I think I made the right choice!
Past Thirdgen:
Past Thirdgen:
Past Thirdgen:
Actually Kyle the TTA rear ends are not that strong. People think they are more strong than they really are. If you have the money go for a Ford 9 bolt. You will not have to worry as much with it.
Car: 2013 C63C
Engine: M156 (P31)
Transmission: 7 speed MCT
Axle/Gears: AMG Limited Slip
<font face="Verdana, Arial" size="2">Originally posted by vinroc:
can you use the harness and ecm from the grand national</font>
).You'd have to combine the GN harness with your original harness,personally I think the outcome would be better with a TTA harness,which by the way you can still get from Caspers Electronics.Or you may find one(or two)used like I did.Also,I personally think the stock 9 bolt is weak but I can't deny hearing of them lasting with some serious power.I myself put a whole season(at least 80 runs)of 1.60-1.63 60ft's on one without problems.
If anyone is interested,I just got a digital camera and have been taking pictures and documenting everything that I've been doing getting my swap done.Just shoot me an email,TTA850@aol.com,I'm glad to help.
Steve
1989 Turbo Trans Am's #124 and #850
1989 Turbo GTA,600hp 3.8L SFI TURBO(in progress)
2001 Kawasaki ZX-6R
I put 300+ runs on my 9-Bolt with a Best 60ft of 1.60 on it. I now have a Dana 44 but the 9 Bolt is still kickin with 103K miles on it.
Get a new TTA harness from Caspers and save yourself some time.
-Mike
89 TTA
-Mike
89 TTA
