priming a 355 and cant get oil to the lifters
Car: 89 camaro
Engine: 355
Transmission: 700r4 w/huges 3000 stall
Axle/Gears: 3.73 posi
i just got done building a 355 for my 89 camaro, it has a egal crank, h-beam rods, kb 11:1 dome pistons, air gap intake, 750 double pumper, mild cam and heads with 1.5 roller rockers.
i went to prime the motor but the oil didnt come out of the lifters like it should have, the pressure gauge reads 50 psi, is ther somehting im missing, im pretty sure that all of the oil plugs are in and everything is sealed up, can someone tell me what im doin wrong or what i can do to fix this?
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: priming a 355 and cant get oil to the lifters
how long did you turn it? It may take alittle while. Keep turning it and see what happens.
Car: 89 camaro
Engine: 355
we turned it for around 45 seconds constiantly and intermidetly while turning the motor over manually
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
45 seconds is nothing, give it a few minutes.
Car: 1982 Camaro z-28
Engine: 307
Transmission: th-350 with stage 2 shift kit
Axle/Gears: stock
You can buy a oil primer rod at auto zone for like 15 bucks, this is better then turning it because every time you turn that camshaft you are taking off the break in grease off the cam. You can also be turning it the wrong way. If you do buy the oil primer rod, you can hear the oil pump if your going the wrong way. Also, if your distributor not in your not turning the oil pump. The distributor is hook up to the oil pump rod thingy.
Car: 88 IROC
Transmission: 4L80E/4L80E
Car: 89 camaro
Engine: 355
ok so im in school tryin to do this, we tried it again n held it for about a min but nothing happened, it build pressure to the oil drain plug on the front of the motor right above the timing cover but wont go any farther, also there is no oil gettin to the top of the heads eather, any sugestions?
Sounds like one or more oil galley plug is missing. Do you have an oil pressure gauge hooked up while you're doing this?
Car: 89 camaro
Engine: 355
yea its readin a steady 50 psi while we prime it
You haven't put the intake on yet, right? Try removing a lifter, say the #1 exhaust, run the pump, and watch for oil down in the lifter hole.
Car: 89 camaro
Engine: 355
ok so we finally got oil to the head, i id have the intake on but we took it off n figured out that the person helping us prime the mototr didnt have the primer in all the way so it wasnt building the pressure needed to get it up top, shortly after we figured this out there had been oil comin up to the top of the head, now all thats left is plug everything else back up n break it in, thanks for all the help once again
quick question, should i keep serpentine or go to old school v belt set up, which is better and easier to run, i have no ac or smog pump on it anymore
Car: 89 camaro
Engine: 355
ok, ive been hearing a lot about e85, what are the benifits of converting to it and what has to be done, im runnin a 750
Likes heat (makes round-robin a lot easier at the track).
To run it, raise the compression to 12-12.5, buy an E85 carb, increase your fuel delivery capacity by about a third.
Car: 89 camaro
Engine: 355
is there a kit i can by to convert the 750 i have or would it be easier to just buy a new card for the e85
Quick Fuel Technologies has metering blocks modified for E85, p/n 34-106.
I have a Proform mainbody and QFT alcohol throttle body, but apparently you can get by with a "normal" 4150 carb. I personally don't know anyone who has used those blocks with one.
Car: 88 IROC
just to add in, there is a Tech Article on here about running the serpentine without the smog pump. Im doing that right now. Only requires a shorter belt. The article mentions everything you need to know about that. Get a AC Delete pulley and you would be set.
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
correction it requires a longer belt. the shorter belt is for those who wish to use underdrive pulleys. i to am doin the same thing
Hotrodboba400
Dec 10, 2019 07:07 PM
RyanJB
Sep 14, 2015 03:39 PM
dimented24x7
Sep 6, 2015 03:51 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
