My 355 Swap ***UPDATE 06/15/2010***
Old Mar 16, 2010 | 05:42 PM
fiream's Avatar
Car: 1983 Pontiac Firebird
Engine: 400HP 350
So for the last year i've been planning an engine build and swap for my 83 firebird. Today started day 2 of the swap. I build then engine over the winter, here are the specs.
1990 Chevy 350 Block
One piece rear main seal
Stock Cast Crank (balanced)
LT1 Connecting rods
SpeedPro Hypereutectic Pistons w/Coated Skirts
10.6:1 compression
CompCams DUAL Energy™ Hydraulic Flat Tappet Camshaft
Details http://www.compcams.com/Cam_Specs/Ca...?csid=105&sb=2
906 casting Vortec Head clearance for .500lift
CompCams valve springs w/titanium retainers and locks
Weiand Stealth Intake
NO carb yet, probably a 750cfm something...
I'm hoping to make about 425hp-450hp. Starting this long process i've gotten pretty far in one day, taking off everything I could that dosent need to be attached the the current 305 in the car so it can come out. So far, the carb, radiator, and accessories are off the front of the engine. all thats left up top is to pull the distributor and some wires need moving, then its on to the drive shaft and cross member and motor mounts. More too come...
Old Mar 16, 2010 | 06:15 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What are the details on the cam? How did you come to decide on it?
Your new engine has the 12 o'clock timing tab. Make sure your new balancer is made for that, or get an aftermarket tab that sits at around 2 o'clock.
Looks like the accessory pulleys were switched over to the later flat multi-groove belt for the alternator. Nothing wrong with that, I haven't had any problems with mine, but they didn't start using that until the '86 model year.
(Interesting engine color, too. . .)
Old Mar 16, 2010 | 06:48 PM
fiream's Avatar
Engine: 400HP 350
Re: My 355 Swap...
Cam Specs:
Valve lift: .462/.482
ADV Duration: 275/277
Center line: 106
Hydraulic-High performance street. Works with stock converter. Choppy idle.
RPM range is 2000-6000
I picked the cam after I heard my buddies 327 with the same cam, it also works very well with the rpm range of the intake.
I do have the balancer for the engine i'll be installing it after the engines in the car. the current engine is an 87 305 TPI converted to LG4 carb so thats the reason for the later pulley's. I like the serp belt setup better anyways.
Oh, and the engine color is "Cast Iron Coat" from Duplicolor.
Old Mar 16, 2010 | 11:53 PM
five7kid's Avatar
425 horse would probably be stretching it for that cam. I would definitely use a higher than stock stall torque converter.
Old Mar 18, 2010 | 08:26 PM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
Re: My 355 Swap...
How much have ya stuck into the thing excluding the intake mani.?
Old Mar 18, 2010 | 10:58 PM
fiream's Avatar
Engine: 400HP 350
Re: My 355 Swap...
Umm, about $1300. The best deal was the heads and intake for $500 and the guy threw in the jasper engine for free..lol I took all the parts out and put what I wanted back in, so it wasnt too bad.
Old Mar 20, 2010 | 09:29 PM
fiream's Avatar
Engine: 400HP 350
Re: My 355 Swap...
SO days 3 and 4 of my swap are done and i've got alot done. Motor and trans are out and the trans is seperated from the "old" 305. Now its on to ordering the trans parts and the rest of the parts for the engine install.. Here are some pics... Any suggestion before I go foreward about anything would be greatly aperciated.
Old Mar 20, 2010 | 09:54 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Re: My 355 Swap...
If you can...get a few cans of engine degreaser and power wash the bay.Wire loom everything and ziptie them for a much more finished install when its all said and done.
Old Mar 20, 2010 | 09:59 PM
fiream's Avatar
Engine: 400HP 350
Re: My 355 Swap...
Yeah thats up for tomorrows agenda. I'm also going to get rid of anything that I dont need and repaint the engine bay black.
Old Mar 22, 2010 | 01:10 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Re: My 355 Swap...
Hey five 7, I built the engine that Rob (fiream) took out, yeah I used the multi rib belt because I like it (I put it on everything, it's my trademark!)
Rob the progress looks great! It's scary seeing that car with the front bumper off after I had painted it and put it all back together LOL. This is why you are taking it apart not me, I don't know that I would have the heart to take that car back apart again but you are building it bigger and better than I did
Old Mar 23, 2010 | 03:38 PM
timespy's Avatar
Car: 91 RS Convertible
Engine: Soon to be swapped
Transmission: Memphis performance 700r4
Axle/Gears: Soon to be changed
Re: My 355 Swap...
Im doing a swap right along the lines of yours. I liked the color of the motor so much I went and did mine the same as you. I thought id do the heads in black, with chrome valve covers, white headers. Sorry to be a copycat, but I really liked the color combo.
Old Mar 23, 2010 | 06:32 PM
fiream's Avatar
Engine: 400HP 350
Re: My 355 Swap...
Neat, im glad im inspiring people..lol
Old May 5, 2010 | 11:00 PM
fiream's Avatar
Engine: 400HP 350
Re: An i'm doing this on a budget...lol *big update*
OKay, update NEW PARTS!!!!! Woooooooooooooooooooooooooooooo..lol
Engine bay done for right now...
Motor DONE!!!
More parts...lol (SFC's not shown, more pics tomorrow)
Rob...
Old May 5, 2010 | 11:42 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Sweet! Its really coming along.
I quite enjoyed building my motor and swapping it, it will most likely be swapped again, haha.
Keep up with the updates.
Old May 21, 2010 | 08:33 AM
fiream's Avatar
Engine: 400HP 350
More photos, Everything is ready to go. I should have the engine back in by this weekend. Then its on to SFC'c and The rear end.
More to come...
fiream's Avatar
Engine: 400HP 350
Old May 21, 2010 | 09:14 AM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
I'd have gone with a Holley carb but looking good just the same.
Old May 21, 2010 | 11:06 PM
fiream's Avatar
Engine: 400HP 350
I went with Edelbrock so I dont have to tune it every other week. I just set it once and I dont have to worry.
Old May 22, 2010 | 06:37 AM
Project-RS's Avatar
what size carb did you run? a650 would be a nice fit. anything bigger and the motor might not like it.
Old May 22, 2010 | 08:30 AM
fiream's Avatar
Engine: 400HP 350
YEah its a 650 CFM Thunder AVs Carb.
Old May 22, 2010 | 09:25 PM
five7kid's Avatar
Yeah, I tuned my Holley just last...
...Hmmm, been too long. Can't remember the last time I "tuned" my Holley.
Old May 22, 2010 | 09:50 PM
fiream's Avatar
Engine: 400HP 350
I dont know, i've had bad luck with holleys, tune them, the car sits for a week or a month, and then it dosent run right till I rebuild them.
Old May 23, 2010 | 02:33 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
haha same here! I tune my holley every.... nevermind only once.
Old May 23, 2010 | 02:55 PM
stroker_SS's Avatar
Engine: 355
+1.
The eddy will work fine, however once you setup a holley as per the SA design holley tuning book you're good to go.
Old May 24, 2010 | 12:36 PM
fiream's Avatar
Engine: 400HP 350
I should have the engine in the car tonight or tomorrow. Mayr I'll have it fired up before the weekend.
Old May 24, 2010 | 03:25 PM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
form the pics, you have one 906 and one 062 head? "saw tooth" head casting is 062?
Old May 24, 2010 | 03:43 PM
He's right..
The 906's on my motor both look like the head on the passener side of your motor.
Old May 24, 2010 | 05:01 PM
one92rs's Avatar
Car: SOLD!!!!!
actually after reading this i went in the garage and looked at my 062 heads and they have the saw tooth front and back.
Old May 25, 2010 | 08:34 AM
fiream's Avatar
Engine: 400HP 350
Originally Posted by bradley23150
He's right..
Yeah I realized that after doing the valve springs. I was suppose to get a matched set of 906 heads, but ended up with one of each. Shouldnt be a big deal, one has the SS valve seat the other dosent.
Old May 25, 2010 | 12:34 PM
i dont know what material the seats are, but 906's got hardened seats. shouldnt be a huge deal
Old May 28, 2010 | 06:04 PM
fiream's Avatar
Engine: 400HP 350
Total fail today. I installed the torque converter on the trans today. I did it wrong and I broke the gent pump on the trans. Total fail
Old May 28, 2010 | 06:15 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
well thats not good.
you are missing a bolt on your passengerside engine mount too.
Old May 28, 2010 | 06:49 PM
its not a total fail, get another pump, have the broken one pulled out and install the new one. good time to upgrade to a 13 vane.... if you haven't already? make sure the converter is totally splined up next time!
Old May 28, 2010 | 08:37 PM
fiream's Avatar
Engine: 400HP 350
13 vane? As in a 4l60e pump??
Old May 29, 2010 | 08:13 PM
fiream's Avatar
Engine: 400HP 350
Anyone know if a 4L60E front pump will work as a replacement for my 700r4 pump if I change the valves in it???????????
Old May 31, 2010 | 04:57 PM
fiream's Avatar
Engine: 400HP 350
Re: An i'm doing this on a budget...lol *fail-tastic weekend update*
Update today. Total fail weekend everything that could go wrong went wrong. There were some wins though.....
Fails:
Broke the transmission fluid pump rotor by not installing the TC right.
Posi that we got off ebay a year ago ended up being bad.
Wins:
Fix the trans with a spare pump rotor from a friend.
New engine in in the car...
Long weekend and I still cant drive the car.
Old May 31, 2010 | 05:29 PM
Awesome-X's Avatar
Car: 87 Camaro
Some minor setbacks, you'll have those on anything you do. It's coming along nicely though, and don't worry I have a 906 and an 063 on my 355 and they're just fine
Old May 31, 2010 | 09:55 PM
fiream's Avatar
Engine: 400HP 350
Just sucks, I wanna drive my car... Anyone got a 26 spline posi they wanna get rid of?
Old Jun 5, 2010 | 12:51 PM
oguin_studking's Avatar
Car: 1990 Firebird Formula
Engine: 358
Transmission: 700-r4
Like how do you know you broke it. I was bolting my flexplate up to the converter the other day & was tightening the last bolt and i heard a loud pop and the T.C. kind of straightened up with the flexplate. Im hopein' i didn't do the same.
Old Jun 5, 2010 | 03:57 PM
fiream's Avatar
Engine: 400HP 350
Yea I broke it pretty good, luckily a friend had a spare 4L60E to get the rotor from.
Old Jun 13, 2010 | 11:05 PM
fiream's Avatar
Engine: 400HP 350
Re: IT RUUUUUUNNNNNNNSSSS!!!!! ***UPDATE 06/14/2010***
***UPDATE***
Motor is done and got broken in tonight here and some pics and a vid!!!!!
Old Jun 13, 2010 | 11:43 PM
  #42
Engine: 358
Lucky! All i need is an edelbrock carb & mine will b running. But, seriously when you broke your gent. pump how did you know that it was broke after installing your converter?
Old Jun 15, 2010 | 09:40 PM
  #43
fiream's Avatar
Engine: 400HP 350
Re: My 355 Swap ***UPDATE 06/15/2010***
Another vid
More pics,
Chuck84TA
Jul 15, 2016 09:05 PM
Reddeath210
Oct 6, 2015 08:20 AM
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
theurge
Aug 21, 2015 12:46 PM
