350 tpi=tbi
Old Apr 6, 2010 | 05:36 PM
bigred75's Avatar
Car: 1992 25th anniversary RS Camaro
Engine: 305 T.B.I.
Transmission: ????
Axle/Gears: ??????
350 tpi=tbi
is it possible to use a 350 tpi from a 91 z28 and put a intake on it and use my tbi system?? the harness on that car is all hacked up and mine is fine. so i figured it would swap as long as i got the knock sensor and ecm.
Old Apr 6, 2010 | 05:56 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 350 tpi=tbi
You forgot the injectors, but do those, and your answer is yes. While you're at it, do Edelbrock's TBI intake.
Old Apr 6, 2010 | 06:13 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You're talking about putting your LO3 TBI system on a 350 L98 TPI longblock, right?
In that case, the injectors and ECM won't do you any good. You're going to need a 350 throttle body and ECM (at least the chip, or have yours reprogrammed).
Old Apr 6, 2010 | 06:23 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 350 tpi=tbi
I think kid missed what you were wanting. That, or I did.
If you have the L98 long-block, to put in an LO3 car, you need an LO5 computer, and LO5 injectors. Everything else swaps over no problem.
Old Apr 6, 2010 | 06:41 PM
bigred75's Avatar
Engine: 305 T.B.I.
Transmission: ????
Axle/Gears: ??????
Re: 350 tpi=tbi
i was planning on getting a carb intake with the adapter plate. so i could just get my chip re burnt to go along with the 350? i dont have the motor yet its still in the car. just wondering if this was an option.
Old Apr 6, 2010 | 09:48 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 350 tpi=tbi
What adapter plate? There's no adapter plate involved in this. If you're wanting to adapt the TB to a carbureted intake, forget it. Not a wise plan. Just use the Edelbrock TBI intake. If you absolutely will not, the Holley Pro-Jection 2v intake will directly take the TB, and have eGR, but it fails to circulate coolant around the TB pad the way the stock and Edelbrock TBI intakes do.
Old Apr 6, 2010 | 10:08 PM
bigred75's Avatar
Engine: 305 T.B.I.
Transmission: ????
Axle/Gears: ??????
Re: 350 tpi=tbi
oh i herd that was the best way to go because there were better intakes that i could use then. but if the edlebrock is better choice il go that way.
Old Apr 6, 2010 | 10:24 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 350 tpi=tbi
If you were getting a set of AFR 180 heads, then I could see a benefit to the adapter and a Weiand Stealth AirStrike (fits under hood better than Edelbrock RPM AirGap, and within 5 ft-lbs at any & all rpm), but the Edelbrock TBI intake outflows the stock L98 heads.
Old Apr 6, 2010 | 10:29 PM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
Re: 350 tpi=tbi
L05 comp won't be any better than the L03 comp, he'll have to tune the car for the L98 cam,
MustangBeater20
Oct 29, 2022 09:20 PM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
