motor swap turned nightmare!!!
Old May 31, 2010 | 11:42 PM
89badass's Avatar
Car: 1989 CAMARO RS
Engine: 5.7 TPI
Transmission: 700R
Axle/Gears: ???
hello everyone , another sad story motor swap. i currently havent been able to drive my 89 camaro for about 6 months thanks to a crappy mechanic and alot of headaches. i swapped out the old tbi for a 350 tpi and havent been able to start the car ever since, i recently just had fuel to the motor and still cant get it to start. i am not too good at working on cars so ive been getting hired help for the time being, this has not been cheap, is there any one on here living close to bell ca? i am in need of help and would appreciate all the advice u guys can offer
Old May 31, 2010 | 11:47 PM
92 Camaro's Avatar
Car: 1992 Camaro RS, 66 Mustang, 78 t/a
Engine: 5.0 TBI, 289, 400
Transmission: 700R4, C4, th350
Re: motor swap turned nightmare!!!
did you swap out the fuel pump?
Old May 31, 2010 | 11:50 PM
juanillox8's Avatar
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
need more info, did u swap the wiring and computer with correct prom?????
Old May 31, 2010 | 11:51 PM
89badass's Avatar
Car: 1989 CAMARO RS
Engine: 5.7 TPI
Transmission: 700R
Axle/Gears: ???
yes unfortunately the fuel circuit did not have power until today. thanks to a briged wire that is sending voltage to the fuel relay
Old May 31, 2010 | 11:53 PM
89badass's Avatar
Car: 1989 CAMARO RS
Engine: 5.7 TPI
Transmission: 700R
Axle/Gears: ???
i did swap out the wiring but the wiring is all over the place and i noticed there were alot of cut wires and some not being connected at all
Old Jun 1, 2010 | 12:03 AM
juanillox8's Avatar
Car: TOO MANY
try to get pics i'll be glad to point you in the right direction... how about computer and prom?? what are the symptoms right now
Old Jun 1, 2010 | 12:08 AM
89badass's Avatar
Car: 1989 CAMARO RS
Engine: 5.7 TPI
Transmission: 700R
Axle/Gears: ???
the symptoms are as follows, the car cranks over but will not turn. i have been stuck at this for a couple of months now, i am thinking of just buying a new harness and having it installed so i can start fresh, would anyone recommend this, also i was told that the computer might be a problem , is a 7165 computer compatible with this engine? its a 5.7 tpi maf with a 700r tranny
Old Jun 1, 2010 | 12:12 AM
juanillox8's Avatar
Car: TOO MANY
it could be if you are not using the right prom theres a 305tpi prom and a 350tpi prom and they would use the same computer also it could be your Vats system have you checked if your injectors are getting pulse in other words are your injectors spitting gas, are you getting spark?
Old Jun 1, 2010 | 12:13 AM
89badass's Avatar
Car: 1989 CAMARO RS
Engine: 5.7 TPI
Transmission: 700R
Axle/Gears: ???
yes they all have spark, how would i get the correct prom for my computer. would i have to buy a new one or is there a way to program the one i have?>?
Old Jun 1, 2010 | 12:17 AM
juanillox8's Avatar
Car: TOO MANY
is better if you buy one unless you have programmers and know how to unlock the one you have, but before you start throwing money on the car check and double check everything you have works and is compatible also check your distributor and make sure your engine is top dead center otherwise you might be 180 degrees off and engine wont fire up, theres so many thing you need to rule out
Old Jun 1, 2010 | 12:33 AM
89badass's Avatar
Car: 1989 CAMARO RS
Engine: 5.7 TPI
Transmission: 700R
Axle/Gears: ???
so after i check the timing what would be the next step to take?
Old Jun 1, 2010 | 12:40 AM
juanillox8's Avatar
Car: TOO MANY
you cant check the timing if it doesnt fire, what i mean by top dead center is that the rotor on the dist is pointing to the 1 cyl when its on its compression stroke and the line on the crankshaft balancer is on 0
Old Jun 1, 2010 | 01:27 AM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
you can tell if the distributor is atleast not 180 degrees backwards cause when it's 180 degrees off it makes a noise similar to a plunger... recheck spark in each cylinder, ground it to bare metal that you aren't touching, then check injectors.
Even if your timing is significantly off, it should sputter when you crank it.
Old Jun 1, 2010 | 07:14 PM
juanillox8's Avatar
Car: TOO MANY
true but if the engine is not at tdc and the dist is way off the engine just wont fire, if its off it ill either backfire or fired and stall right away but checking each cylinder is a good idea to start with,
Jorlain
Aug 24, 2022 05:11 PM
Andrew6.688
Dec 13, 2015 10:59 AM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
st.evel07
Aug 13, 2015 06:15 PM
92projectcamaro
Aug 6, 2015 01:20 PM
