305 TPI < 350 Carbureted: Need Advice
Old Jun 13, 2010 | 01:40 PM
themaxman's Avatar
I'm swapping out my 305 TPI to a 350 carb crate engine, and I am looking for some information on swapping the wiring and cleaning up the engine bay from someone who has done it before. The car is an 85 IROC Z.
Is there a wiring diagram for the EMS that I should stick to?
What is required for the TPI to carb swap (specifically with the electric fuel pump) in order for it to work properly?
Any other helpful advice would be greatly appreciated.
Thank you in advance.
Old Jun 13, 2010 | 04:21 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
In the Carburetor forum there is a sticky in the top section called "Welcome to the Carburetor forum". In it is a link to a tech article about converting from EFI to carb.
Not sure what you mean by "EMS". "ECM", perhaps? The computer? All of that wiring is contained in a bundle that goes to the passenger fender well. You can unhook everything that it goes to, unhook it from the ECM, and pull it out in one piece. Everything you need will still be in the engine compartment coming from the other side of the firewall. Unless you have an automatic transmission, in which case the torque converter lock-up harness just left the building with the ECM harness.
Why not just put the TPI on the crate engine?
Old Jun 13, 2010 | 05:03 PM
themaxman's Avatar
Re: 305 TPI < 350 Carbureted: Need Advice
Yeah, I meant ECM, been a long day =P
After reading your reply I see now that it may be unfortunate that I have an automatic transmission. So that being the case, is the torque converter lock-up harness the only part of the ECM harness that I need to salvage from it?
The reason I am going with carb is because every person I talked to about my "end game" dreams for this car suggested to go with carb, along with being able to get a lot more power in the long run, they also indicated that it is a lot cheaper, which is good because I'm a student.
Thanks for the help, and the carb info.
Old Jun 13, 2010 | 06:54 PM
tylerv350's Avatar
Car: 1982 z28/rs... haha
Engine: 305(now) 333(soon)
Transmission: 350 3-speed automatic
Axle/Gears: 3.45 limited slip 10 bolt
so what problems would occur from pulling an ecm? i pulled mine just for a day, drove without it and everything and it was all fine. would it be that somebody swapped both the engine and transmission from my camaro?
Old Jun 13, 2010 | 11:14 PM
five7kid's Avatar
For one thing, when you start with an EFI engine, the ECM powers the fuel pump. There is an oil pressure switch in parallel, but it would require oil pressure (obviously) to turn on the fuel pump.
An '82 would have a TH200C (not TH350), which uses the ECM to lock up the torque converter. Not having functioning lock-up is not as critical with a TH200C as it is with a TH700R-4.
Old Jun 14, 2010 | 09:23 AM
tylerv350's Avatar
okay. but everything started up and ran fine.. almost better and healthier than it did with the ecm. i know that the tranny wouldnt have been the th350, but somebody swapped the old one out for that one.
Old Jun 14, 2010 | 04:00 PM
five7kid's Avatar
Okay, just clarifying. Is it a TH350, or TH350C? If it is the latter, it will have an electrical connection above the pan rail close to the shifter shaft.
Old Aug 4, 2010 | 06:02 PM
tylerv350's Avatar
th350
BlueIroc-Z
Jun 9, 2019 03:22 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
