engine swap
Old Jun 22, 2010 | 08:30 PM
thebluearcher's Avatar
Car: 92 Camaro RS 305 5 speed hopefully
Transmission: 5 speed
engine swap
I have an 88 iroc with 305 tpi w/maf (it is wrecked) I just bought (ok a year ago) a 92 rs 305 that had tbi (engine was blown and not in the car but I have all parts) I want to put the iroc engine in the 92. now from everything I read on this message board there is some difficulties with this swap. here is the question. would it be best to swap the entire engine, ECM and dash harness along with the guages to do this swap. I should also say that the iroc tranny is auto and the 92 is a 5 speed manual. or is there a better way?
Old Jun 23, 2010 | 01:49 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
The issues involve the type of speedometer in each (cable drive for the '88, electronic transmission-mounted VSS for the '92), VSS buffer box in the '92, and VATS in the '92. If you change out the entire harness and dash, putting all of the '88 stuff into the '92, you will "solve" those issues.
However, if you want to use the 5-speed from the '92, you'll run smack back into at least a couple of them.
Old Jun 23, 2010 | 12:45 PM
Re: engine swap
if I use the 5 speed what would the couple of problems be that I would get back?
Old Jun 23, 2010 | 03:28 PM
five7kid's Avatar
The transmission mounted VSS. You'd either have to convert the tranny to cable drive speedometer, or do some work-arounds.
Old Jun 23, 2010 | 07:45 PM
Re: engine swap
so will i need a different ecm or will the 88 auto work with 92 5 speed tranny?
Last edited by thebluearcher; Jun 24, 2010 at 06:55 AM. Reason: to make a clarifaction
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
