Questions about a 305
Car: 1988 Pontiac Firebird
Engine: 4bbl 305
Transmission: Turbo 350
Hey you guys, its been awhile since my last post...I have since found out that what i thought was a 350 was indeed a 305, so where im at right now is that i have my 305 being taken apart day by day, what im here to ask is will my project work with what i have without me having to get more parts. here is what i got, carbed 305 out of a 1986 Camaro, 84k miles on the motor, New main,rod, and cam bearings, New CSB complete gasket set, .292/.292/.488/.488 i believe are the numbers on my new cam. I have a turbo 350 tranny to put behind it, i just want to know if that will work or would it bomb? also i was told my car came with 411 gears because it came with a v6, to make up for power, is this true? I have a 1988 firebird that came with a 2.8Lv6, please let me know, Thanks
Engine: 4bbl 305
Re: Questions about a 305
thanks, my main concern is the cam, i was told it would be a pretty rowdy cam for a 350, i wanna make sure i can run it in my 305 while still running stock internals, i also forgot to add i have gm performance heads aswell.
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
You dont have nearly enough stats on that cam to know anything about it. Assuming it's .488 lift on the intake and exhaust side that puts it in fairly tame company for street car cams, the problem is if that's all the numbers you got for it, it's probably an old school grind that's not all that good at giving you a nice usable wide powerband like the newer cams do.
Engine: 4bbl 305
http://www.summitracing.com/parts/SUM-1106/
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Way too much cam for a 305.
All the '85-up v6 cars built with automatic also got 3.42:1 gears. The T5 V6 cars got different rear gears in different years. In '85, it was also 3.42:1, because the '85 V6 t5 had a 3.50:1 first gear. But for '88, the V6 T5 got a 4.03:1 first gear, so the axle dropped to 3.08:1.
If you're gonna put a Summit cam in the 305, limit yourself to the 1102, which is 420/442 lift. You'll hate it if you go any bigger.
Engine: 4bbl 305
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Probably NOT. Probably 2 reasons. One is the springs, the other is the retainer-to-guide clearance. Changing the cam is the cheapest solution. Or use the 305's stock cam.
Transmission: 4L80E/4L80E
Wow, the mismatch continues.
A $55 cam would be cheap insurance against frustration. But, those Fast Burn heads wouldn't work well on a 305 without making the whole thing pretty much unstreetable.
Engine: 4bbl 305
Well, I have a daily driver already, if its almost unstreetable I wouldn't have a problem with that lol
On Probation
Engine: several
Transmission: none
Axle/Gears: none
The list of crap parts you already bought, it defies all reason. You start with a lame old cam, and now you add the second worst non-production SBC heads ever conceived. Those heads don't even flow as well as the iron Vortec 350 truck heads, despite larger intake valves, (which won't clear a 305's tiny bores) and another 40 cc of intake port volume. That's why they're crap.
Look, sell them, and the stupid cam, and buy some sensible parts.
If it seems like we're ganging up on you, then that should help convince you of your error. We're here to help. five7kid can't type some of the things I do, because he's a moderator, but the message is the same.
Car: '83 WS6 T/A 65,000 miles
Engine: 5.0L vin H stock, 406SBC right now
Axle/Gears: Corp. 3.73
Engine: 4bbl 305
I was asking for some simple answers, Im appreciative, I really am, but i feel some of the things you said were rather rude, I guess either way I got my answer.
Engine: 4bbl 305
Low funding, pretty wild and 305 don't make a very good combo. You will get many opinions about how to buid it and how to spend your money.
If you are using a carbed set up I say get good vortec heads, a moderate (for a 305) cam...212 to 220 split profile duration @ .050...maybe some 1.6 rockers, a highrise (Edelbrock RPM) type manifold and a good Q-Jet carb. With good exhaust components this engine will make decent power. This combo can work with or without electronics. Add gears and it will roll out nicely.
FI is a different animal I wil let someone else explain.
You can sell the parts you have and buy used items to complete the job....or rob a convience store!
Engine: 4bbl 305
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
