need help asap
Old Aug 16, 2010 | 04:34 PM
mr iroc's Avatar
Car: 88 iroc
Transmission: 5 speed
Axle/Gears: dount know
need help asap
i am swaping in 78 a chevy small block 400 into a 88 iroc with a world calss t5 what i need to know is what starter will work with this combo and what kind of car i would find it in it has to be a diagonal bolt patern any one know?????
Old Aug 16, 2010 | 04:37 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: need help asap
You need to drill and tap the block for the 153-tooth starter pattern.
Old Aug 16, 2010 | 04:53 PM
mr iroc's Avatar
Car: 88 iroc
Re: need help asap
would rather not drill and tap the block any one elts know??/
Old Aug 16, 2010 | 04:56 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: need help asap
There's no alternative. The staggered hole is directly through where the body of the starter would need to be to fit the 153 tooth flywheel, and a 168 tooth flywheel won't fit inside the T5 bellhousing.
Old Aug 16, 2010 | 05:56 PM
I_R_O_C_Z_2_8's Avatar
Car: 1991 Trans Am GTA
Engine: 350 tpi
Re: need help asap
hmm dont mean to hi jack a thread but im curious as i will be swapping a 75 350 into my iroc....i bolted up the starter and it fits fine but dont have the flex plate on will i have a problem?
Old Aug 16, 2010 | 06:00 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: need help asap
Not if you use a 168 tooth flexplate. Certain headers might not clear the starter, though.
Old Aug 16, 2010 | 06:08 PM
Engine: 350 tpi
Re: need help asap
well im running a auto so need the 153 one and im running shorty headers. just some ones i pulled off another iroc..
Old Aug 16, 2010 | 06:15 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: need help asap
You can put either flexplate on an automatic. It's the T5 that gives him a problem, the bellhousing is too small for the 168.
Old Aug 16, 2010 | 10:36 PM
toolegit86's Avatar
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
Axle/Gears: disk rear, 10bolt.
Re: need help asap
you will need one of these to run the 153 tooth flywheel
http://www.kmjent.com/cart/product.p...7109850&page=1
the 153 tooth is the only one that will work in the t5 bellhousing.
and ur best bet is to get a aftermarket starter the high tq ones cause ur going to need it anyway
Old Aug 16, 2010 | 10:39 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: need help asap
To use a stock 305/350 flywheel, or you can just get a 153 tooth flywheel for the 400.
Old Aug 16, 2010 | 11:47 PM
toolegit86's Avatar
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
Re: need help asap
you have to get a aftermarket external balanced flywheel to work on the 400. that why there is that added weight to make the stock 305/350 flywheel to make it external not internal
Old Aug 16, 2010 | 11:57 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: need help asap
Yes, exactly.
92GTA
Apr 9, 2016 07:39 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Brother Al
Oct 14, 2015 06:39 AM
92projectcamaro
Sep 24, 2015 08:09 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
