1986 Camaro 305 to 350 what need
Old Sep 6, 2010 | 12:57 PM
MetallicaWolfe's Avatar
Car: 1986 Berlinetta Camaro
Engine: 350 SWAP
Axle/Gears: Stock
Okay my car has 191k miles on it, not sure if the 305 was ever rebuilt. Its been reliable for the past 2000 miles but you never know what may happen. Burns oil and has a really noticable difference in power in the morning and during the day, which of course hot weather yadda yadda ya.
I just want something fresh but a new car isn't an option since I'm in college haha.
So I'm looking at buying a crate 350, now I need to know what I can and what I should not take from my 305 and put plug it into the 350. Ive heard that I should get a new harmonic balancer, so I got down that much besides a new intake manifold. Also whats the difference in a 6'3/4 and 8'' balancer. Internal, external?
I'm no expert but I can learn.
Also the damn thing seems to barely get over 10mpg city, sometimes worse, best I ever got from it was like 18mpg mostly highway
Old Sep 6, 2010 | 01:34 PM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Re: 1986 Camaro 305 to 350 what need
congrats on you project !!!
your engine is internally balanced
the smaller balancer will allow the engine to rev quicker..
you will need to purchase the matching timing tag..
I would suggest you change your electronic distributer.. to centrifugal, vacuum advance
replace your carb with a non computer controlled
also a Qjet will give you better mileage there are mods you can do to Qjets
a performance intake would be a nice welcomed change
or maybe sell your setup... for EFI with much better mileage just a thought with gas prices...
Old Sep 6, 2010 | 01:43 PM
Engine: 350 SWAP
Axle/Gears: Stock
I already changed my distributer and carb, edlebrock 600, eh the way I see it, this is the best option $ wise
Also timing tag, can anyone tell me what he meant, you mean timing tab?
Old Sep 6, 2010 | 11:09 PM
88gta3508's Avatar
Engine: 231 / 383
yes TAB
Old Sep 8, 2010 | 09:56 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Use Good headers ( 1 3/4" ) and Y-pipe leading to a 3" cat back exhaust. Install a "high rise" intake ( RPM / Air Gap) and a 1" spacer on top; but only if you have the space ! You could also get a drop-base air cleaner to save some room. And be sure to use the correct flywheel ! ( 1 or 2 piece RMS block )
Be sure to upgrade the factory sway bars on your car too - It will be a very different ride with a 350ci in it !
Old Sep 9, 2010 | 01:27 PM
Engine: 350 SWAP
Axle/Gears: Stock
Thanks for all the feedback, I'm looking into all this right now. Heres a few things;
http://www.jegs.com/i/GM+Performance...67353/10002/-1
Yes, stock but daily driver and much much better than my stock 305
http://www.jegs.com/i/Weiand/925/8150P/10002/-1 which one is better and why? you told me highrise which I imagine keeps things cooler etc My first pick was the one below;
http://www.jegs.com/i/Edelbrock/350/2701/10002/-1
And yeah I dont have too much room to work with, enoguh but not sure for a 1'' adapter plate, well see.
http://www.jegs.com/i/Proform/778/66510/10002/-1 I assume this will work.
Not sure what flywheel to get, I assume a 1985 350 one will work, mine needs replaced anyway so yeah, starter misses from broken teeth haha
And all this is fairly new: My
starter
battery
alternator
fuel pump
edlebrock 1406
and not that its all that important but my tires dont even have 10k miles on them haha
http://www.jegs.com/i/JEGS/555/30565...68#moreDetails <----Is there any reason that wouldn't fit? couldn't find much on what Ive been looking for, of course headers to match
Old Sep 9, 2010 | 03:39 PM
camarodave988's Avatar
I am currently doing the same swap but i have a 1985 camaro. I am slowly working on it when i get time because i have the car at my cousins house. I was curiouse if i could pull the motor out with the cherry picker with the stock headers still connected to it. I would greatly appreciate the help because they are rusted in good.
Dave
Old Sep 9, 2010 | 04:48 PM
Engine: 350 SWAP
Axle/Gears: Stock
Dave
Thats cool, I honestly don't know, still getting parts ready etc I need mine completed within a weekend so haha, my daily driver, wish I had a second car, would make things so much easier
Old Sep 9, 2010 | 05:00 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
1) It ain't gonna happen in a weekend - make arrangements for other transportation or don't do it. It NEVER happens in a weekend. You'll get the block swapped, but tuning it to run good enough to daily drive - better give yourself a safe alternative.
2) The Performer EPS is NOT the intake you want. Get the Edelbrock Performer RPM or the Edelbrock Performer Air Gap. Stay away from the Air Gap RPM (it's too tall).
3) A 1in spacer will not fit either (not on top of a good intake) - skip it - not needed.
Old Sep 9, 2010 | 05:12 PM
Engine: 350 SWAP
Axle/Gears: Stock
Of course I'd make sure to have other options just in case, jst going off of estimates from someone whose has done it haha.
Good, just shopping around-
I plan on sticking it in the shop after swap for fine tuning, depends really.
Old Sep 12, 2010 | 12:30 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Use Good headers ( 1 3/4" ) and Y-pipe leading to a 3" cat back exhaust. Install a "high rise" intake ( RPM / Air Gap) and a 1" spacer on top; but only if you have the space ! )
1-3/4" headers are too big for that engine. The RPM intake is more than needed (the EPS would be fine on that engine). Spacers are overrated, especially on a stock-type replacement engine like that.
Sorry to hear you downgraded the carb and distributor.
Old Sep 12, 2010 | 09:00 AM
John in RI's Avatar
OK -
If that's too much; stick with a stock 305 TPI manifolds / Y-pipe and cat back,..... ?
Any extra spacer/gasket under the carb is good to prevent heat soak, and while a 1" will do nothing for a 305, I nave never read "in print" where it it will not help a 350. If you have the space to install it, it should - IMO - be installed.
Get under the car and remove the 2 original studs/bolts that hold the Y-Pipe to each manifold. Expect them to break and need replacement,.....! A deep socket some extensions and a breaker bar will make short work of it. ( place a jack under the Y pipe so it doesn't fall on Ya' when the last stud is broken off. ) The Y-pipe will drop and the engine can be pulled with the manifolds in place.
They should work just fine on top of the new 350, regardless of the intake they are sitting on !! ( You don't want a CC LG4 set-up on there ! )
Old Sep 13, 2010 | 02:08 AM
Engine: 350 SWAP
Axle/Gears: Stock
http://cgi.ebay.com/ebaymotors/CHEVY...Q5fAccessories
What Im currently looking at over new crate, in yellow
Old Sep 13, 2010 | 08:25 PM
Naldo's Avatar
I am working a 350 from 305 swap also - i gave in to the "dont be foolish and rebuild that 305" crowd. i kinda knew i was going to. Got a good deal on a 350 motor from a guy on craigslist - it was in a nova he claims to have only run this past season on the 2010 cruise nights. Its clean enough, gaskets look pretty fresh. .30 over, Domed pistons, lunati 300 cam - a bit more cam than i was really aiming for but the price was right. Holley fuel pump, "heavy duty" oil pump - not sure what that means, what looks like an edelbrock intake, but i cant find any manufacturer name or logo's on it, with a holly 650dp. He threw in a set of shorty headers. all for about 2/3's of what i was looking to pay for a Top End Kit from Summit.
So now i have the motor and trans out - and what appears to be considerably more wires than i need. What is the standard practice for (burying?) the unused wiring? ill need the essentials and some sending unit info from the water, alt and oil pressure, etc. of course, but that leaves a whole lot of wiring with nothing to do.
oh yeah - rust inhibitors... are these more like snake oil or do they actually stop rust? my intention is to clean up the engine bay and paint it up, but if i had to sand to bare metal thats going to take some time.
Old Sep 13, 2010 | 09:03 PM
Doom86's Avatar
Car: '86 Z28, '91 RS
Engine: 305ci, 305ci
Transmission: TH200c (no kidding), TH700r4
Axle/Gears: 2.73, 2.73
Why is that?
Old Sep 13, 2010 | 10:47 PM
Car: 1992 RS
Engine: Carbed 350
Originally Posted by Naldo
He threw in a set of shorty headers. .
Unless these headers are 3rd gen F-body specific, they will not fit in your 3rd gen car, so take them off and sell them.
Old Sep 14, 2010 | 06:56 AM
Naldo's Avatar
Well- they are not mounted, and i had planned on installing the motor and then putting them in. Aside from the fact that they wont match directly to the Y pipe, whats the hangup? or do the F body specific type match the stock y pipe?
Old Sep 14, 2010 | 09:30 AM
Car: 1992 RS
Engine: Carbed 350
Headers are pretty much car specific. In the old days of huge engine bays many headers would fit many car applications, but that's no longer the case. There's generally a problem with the K member or A-arms or steering with trying to use the old shorty headers.
Hey - they were free, by all means give it a shot. I've not personally tried it myself, but I've read alot of posts here where nothing but 3rd gen specific headers would fit. But I'd definitely install the motor first (by placing motor on mounts but not putting the bolt through the mounts yet) then try and see if the headers will fit (not bolting up the mounts will allow you to lift motor slightly if needed). It'll cost you nothing but time to try, and maybe you will get lucky.
Old Sep 14, 2010 | 01:54 PM
five7kid's Avatar
The stock factory CC E4ME computer q-jet and associated distributor would be perfect for that engine. You couldn't possible do better. Edelbrock should be shot for foisting their carbs on an unsuspecting public. Anyone suggesting removing a factory CC carb from a street/performance 305-383 should meet a similar fate.
Factory TPI exhaust manifolds and exhaust (except the '91-'92 single cat version) would be fine, or headers & cat-back for the '86-'90 TPI single cat application. Shoot for 1-5/8" primary tube headers (avoid Pace Setters or Flowtechs or any of their branded derivatives).
Old Sep 16, 2010 | 05:50 PM
Naldo's Avatar
i mentioned rust inhibitors - maybe i meant rust arrester? the stuff you can spray/paint onto rusted metal that supposedly stops it from continuing to rust? has anyone tried it and can say "yeah, it does what it says" or " tried it and the thing was bleeding rust in two weeks.."
just hate to waste time if i can pick brains on folks who've been there done that.
Also - is the Lunati cam i mentioned (300 duration 515 lift) Way more than should be driven more than a quarter mile at a time? what if i wanted to go like 25 miles - would i wish i didnt have such a large cam? The motors out of the car now - if i have to swap cams, now would be the time. I just have no idea what the difference is going to be from the stock cam it had to this new one and am wondering what to expect.
Old Sep 23, 2010 | 08:23 PM
Engine: 350 SWAP
Axle/Gears: Stock
Just ordered the new crate 350 Woooo
Going to get a paint job soon aswell, I'll update as needed
Btw we are doing the swap at my sisters boyfriends grandpa's shop
So excited (^.^)b
Old Sep 28, 2010 | 07:38 PM
Engine: 350 SWAP
Axle/Gears: Stock
Okay so still waiting on the engine, should be in tomorrow, anyway have a few questions;
If im not mistaken thats part of my cruise control correct?
What are these sensors for? I bought a new water neck and it doesn't have them. I'm guessing it has something to do with reading the fluid temperature?
Wouldn't be complete without a horrible shot of the horrible looking dismantled 305.
Old Sep 28, 2010 | 07:48 PM
John in RI's Avatar
Why is that?
Cause' no one would want a 305ci CC carb, CC distributor, and ECM running a crate 350.
Yup, That's part of the cruise control.
One water neck sensor is coolant temp to ECM and the other is a vacuum switch for stock carb set-up.
Glad to see the project is progressing !
Old Sep 28, 2010 | 09:59 PM
Doom86's Avatar
Well I gathered that was your opinion the first time you said so but was wondering why.
To the OP the water neck pictured there has a Coolant temp sensor on the left and the solenoid on the right is for the evap canister.
Old Sep 29, 2010 | 12:19 AM
five7kid's Avatar
You'd have to be ignorant or untrainable to think that.
Old Oct 20, 2010 | 07:32 PM
Engine: 350 SWAP
Axle/Gears: Stock
Heres more pictures from Sunday! Getting so close! Working on it more tomorrow Wiring seems just fine, had to fix starter wire again but its a ok =] The starter housing was cracked big time hahaha..Wonder if my warranty covers? ;D
Old Oct 20, 2010 | 07:34 PM
Engine: 350 SWAP
Axle/Gears: Stock
Old Oct 20, 2010 | 09:03 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Nice progress being made. You can lose ALOT of that wiring if your not sticking with a cc carb. Check out Pocket's wiring threads for some instruction. I believe its called: "Prepping a 3rd gen harness" or something along those lines.
Old Oct 21, 2010 | 09:53 AM
John in RI's Avatar
Ignorance is Bliss !
Looking good,.......... Looks like your Well on your Way !! I havn't pulled an engine in 3-4 months and seeing these pics is giving me the 'itch' !
Old Oct 21, 2010 | 01:33 PM
Engine: 350 SWAP
Axle/Gears: Stock
Yea I might look into it, depends how much we get done today etc
Might just leave it alone and cut things up later after I actually have a car that runs lol...
Haha only 3-4 months? ;D
Hopefully I'll have more to update today
Old Oct 22, 2010 | 07:35 PM
Engine: 350 SWAP
Axle/Gears: Stock
Heres some updates from yesterday and today =D Got the intake manifold on yesterday, gaskets and that glue stuff then today paint and flexplate bolted on along with spark plugs. Spending so much money but getting sorta excited!!
Got my starter replaced on warraty, it was cracked, XD Ordered a new power steering pressure hose and whatever the other hose is called. New transmission seals and new engine thinga majigs, forget the name...Holds the engine down. Also got transmission piece...The water pump is new aswell, old one was nasty ^^
I'm forgetful of the names..
Anyway what would you guys reccomend oil wise? Full synthetic?
Old Oct 22, 2010 | 07:53 PM
John in RI's Avatar
Your Feelin' it alright !!!!
But a good oil filter and the cheapest oil you can buy...... get whatever viscosity/wieght was recomended for the motor. Run the block thru it's "break in" period and replace oil and filter with new stuff. This time buy premium oil for the correct viscosity/wieght.
( consider the first oill / filter as a "flush" for any crap that might have gotten inside buiring the build )
Old Oct 22, 2010 | 08:08 PM
Engine: 350 SWAP
Axle/Gears: Stock
Ok I'll take that into consideration man =D
Old Oct 22, 2010 | 08:18 PM
I've also heard that diesel oil is a good break in oil to use.
Old Oct 22, 2010 | 10:52 PM
Engine: 350 SWAP
Axle/Gears: Stock
Oh I wouldn't know haha
Probably going to have the transmission on by Monday
It runs strong so I'm not going to screw with it =D Ive changed the filter and o ring on it not long ago, like last year so yeah. Shifts normal, haven't been able to tell it apart from a newer cars transmission so thats a good sign.
Going to wait to cut wiring, dont really feel like getting too far in depth with it. Just need it running Updates soon
Old Oct 22, 2010 | 10:53 PM
five7kid's Avatar
Cheap oil probably isn't a good idea. You want the ZDDP for the cam break-in, which is still in the diesel oil spec'd for '06-earlier, CI-4++ and SL (for the gasoline engine side). You don't want CJ-4 diesel oil, as it has reduced ZDDP. Non-synthetic.
After the cam break-in, dump the oil, change the filter, and use the same diesel oil for the first 500 miles or so. Then you can go to whatever you want. I'm a firm believer in synthetics, AMSOIL in particular. Since you have flat tappet lifters, you'll want to keep using a CI-4++/SL rated oil. If it says SM, SN, GF-4, or GF-5, don't use it - those don't have sufficient ZDDP, and you'll risk wiping out the cam or lifters.
Old Oct 22, 2010 | 10:59 PM
Engine: 350 SWAP
Axle/Gears: Stock
Thanks man, saving me alot of time in research. By the way, how long does it take to break the cam in?
Old Oct 22, 2010 | 11:07 PM
Doom86's Avatar
looks good man glad to see it's coming together.
The best place I found for break in oil is the machine shop. YMMV but my local shop was good. Don't use cheap oil when you could just spend $20-$30 on the proper oil. It would really burn your *** to wipe a lobe to save $5.
Old Oct 28, 2010 | 03:43 PM
Engine: 350 SWAP
Axle/Gears: Stock
What would be a proper break-in and break in period? Im reading and nothing is the same xD I need my car for daily driving, in college
Old Oct 30, 2010 | 10:31 PM
Engine: 350 SWAP
Axle/Gears: Stock
Not a whole bunch has been completed- getting back on it tomorrow-grr getting aggravating. This update includes the transmission rear and front seal replacement, the water necks are in and locked, the water pump is on and assembled and I made my own plug for the drivers side dipstick, wooo
New motor mounts in, well the part that goes down on the frame...lol
Old Oct 31, 2010 | 06:12 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
No disrespect, Tim, but some of us are old-school, and are not interested in computer-controlled crap on our cars, with the mess of wiring and harnesses, sensors, and pulling our hair out figuring out where everything goes. A friend of mine recently replaced the 327 in a '67 Caprice with a GM crate 350, and it was such a straight-forward, simple, stress-free swap. HEI distributor, regular Q-jet, and a nice, neat clutter-free engine compartment. It's all a matter of preference, and while I know that there won't be any horsepower gains from going to non-cc, I've always found that keeping things simple as possible works best for my limited intelligence...
Old Oct 31, 2010 | 07:07 PM
  #42
Engine: 350 SWAP
Axle/Gears: Stock
Well didn't get what I wanted done today...Heres an update to what I have done, slowly but surely it will get done...so ****ing close!
Old Oct 31, 2010 | 10:19 PM
  #43
T.L.'s Avatar
'Looks real good. 'Not really digging the yellow exhaust manifolds (will that paint even take the heat??), but to each his own...
Old Nov 2, 2010 | 07:35 PM
  #44
Engine: 350 SWAP
Axle/Gears: Stock
Thanks, technically it should, high heat engine paint
Old Nov 2, 2010 | 08:20 PM
  #45
Doom86's Avatar
Those manifolds are going to choke the crap out of this thing. Sorry man not trying to **** on your parade just being honest. It's going to feel like your are driving a work truck until you get those swapped out.
Old Nov 2, 2010 | 08:46 PM
  #46
Engine: 350 SWAP
Axle/Gears: Stock
I know it =p
Old Nov 3, 2010 | 02:04 PM
  #47
five7kid's Avatar
No offense taken. I'm old enough to have driven a new '67 Impala (okay, just around the farmyard), and it's not simply a matter of preference. A few minutes, or even hours "hassling" with wires and sensors is paid back with hours, days, months, and years of easy starts, good throttle response, good fuel economy, and as good or better power. I see no reason to go back to a harder, dirtier, more-maintenance-intensive time.
Old Nov 3, 2010 | 02:05 PM
  #48
five7kid's Avatar
High heat engine paint is no match for high heat exhaust manifolds.
Old Nov 3, 2010 | 02:15 PM
  #49
five7kid's Avatar
This used to be on GM's sites for their replacement engines:
1. Always put safety first. If your car is on the ground, be sure the emergency brake is set, the wheels are chocked, and the transmission cannot fall into gear.
2. Be sure to check the engine's oil level and prime the oil system.
3. Run the engine between 2,000 and 2,500 RPMs, with no-load on the engine for the first 30 minutes.
4. Adjust the distributor timing roughly by hand for a quick start-up and the smoothest idle possible.
5. Adjust the carburetor settings, if necessary.
6. After the engine has been running for 30 minutes, set the ignition timing (see install ignition section for timing specifications).
7. Drive the vehicle with varying speeds and loads on the engine for the first 30 miles. Be sure not to use a lot of throttle or high RPMs.
8. Run five or six medium-throttle accelerations to about 5,000 RPMs (55 to 60 MPH), then let off in gear and coast back down to 20 MPH.
9. Run a couple hard-throttle accelerations up to about 5000 RPMs (55 to 60 MPH), then let off in gear and coast back down to 20 MPH.
10. Change the oil and filter with 10W30SG oil and PF1218 ACDelco oil filter (PN 251605610).
11. Drive the next 500 miles normally, without high RPMs (below 5,000 RPM), hard use, or extended periods of high loading.
12. Change the oil and oil filter again.
13. Your engine is now ready for many happy cruising miles.
At #10 & #12, you need to abandon the current rated oils and use the CI-4++/SL rated diesel/gasoline engine oil. If you want to use synthetic oil, do that at #12 (but still only use a CI-4++/SL rated diesel/gasoline engine oil).
Old Nov 3, 2010 | 08:29 PM
  #50
Engine: 350 SWAP
Axle/Gears: Stock
Ok, I'll try to follow those steps haha...Also what about the engine knock sensors?
How important are those since Ive changed distributers etc?
Still use by ecm?
