305 to 350 help
Old Sep 13, 2010 | 02:24 PM
WhyNot'87's Avatar
Car: 87 Camaro
Engine: 383 Stroker
305 to 350 help
Well i just got my 305 out of my 87, picking up the 350 sometime next week, just wondering what fits what doesnt and some tips
extra details:
its a drag race build, so street legal is not needed
has a 700R4 tranny
trying to elimanate the wiring harness for the most part and go with race harness
both carbed.
thanks
Old Sep 13, 2010 | 02:42 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: 305 to 350 help
If you're asking about externally, everything will fit. The block is the same and the bolt holes in the heads and manifolds are identical. Unless the 350 has Vortec heads and intake on it.
Old Sep 13, 2010 | 02:50 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 305 to 350 help
What year is the 350 block?
Old Sep 13, 2010 | 03:14 PM
WhyNot'87's Avatar
Car: 87 Camaro
Engine: 383 Stroker
Re: 305 to 350 help
what about tranny wise
and the guy said it was an 80's
Old Sep 13, 2010 | 03:17 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: 305 to 350 help
Need to know what year in the 80s it was.
Old Sep 13, 2010 | 04:29 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Re: 305 to 350 help
Do you have the casting number on the block? That will tell us the type of block you have. If not, look at the valve covers. If the hold-down bolts are on the perimeter of the covers its and 86- block, if it has 4 bolts in the middle of the cover its an 87+ up block. Assuming they are the original heads of course. The 700r4 should bolt up to the block just fine regardless. However, you might need a new flexplate.
Old Sep 13, 2010 | 04:45 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: 305 to 350 help
Valve cover bolt pattern will tell you what year the heads are, but not the block.
Old Sep 13, 2010 | 08:38 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Re: 305 to 350 help
That's why I said "Assuming they are the original heads"
Otherwise the only external difference I know of between 1-piece RMS & 2-piece RMS blocks is the flexplate needed to bolt to the crank and whether or not the hole is there for the fuel pump pushrod.
Old Sep 14, 2010 | 01:35 AM
WhyNot'87's Avatar
Car: 87 Camaro
Engine: 383 Stroker
Re: 305 to 350 help
well the engine is in storage righ now im going to get it on sat so ill get the casting #. but, 92RS_Ttop if that is the case a new flexplate would sole the problem?
Old Sep 14, 2010 | 09:24 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: 305 to 350 help
If it's a 1 piece RMS you can replace the flexplate to make it work, no problem.
Old Sep 14, 2010 | 09:45 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Re: 305 to 350 help
Exactly my thoughts as well
Old Sep 14, 2010 | 06:49 PM
WhyNot'87's Avatar
Car: 87 Camaro
Engine: 383 Stroker
Re: 305 to 350 help
are the motor mounts the same too?
Old Sep 14, 2010 | 07:08 PM
StealthElephant's Avatar
Car: 87' Iroc
Re: 305 to 350 help
I believe they are.
Old Sep 14, 2010 | 07:13 PM
WhyNot'87's Avatar
Car: 87 Camaro
Engine: 383 Stroker
Re: 305 to 350 help
i sure hope so :/ any tips on the swap from anyone that has done it?
Old Sep 14, 2010 | 10:25 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Re: 305 to 350 help
Yeah, the mounts are the same. Just use the clamshells from your 305 and get new replacement rubber mounts. If the 350 has clamshells on it and you don't know what they are from and they may not work. The are F-body specific, not 305/350 specific.
Old Jan 17, 2011 | 12:57 AM
WhyNot'87's Avatar
Car: 87 Camaro
Engine: 383 Stroker
Re: 305 to 350 help
ok here are the details 1970 Chevy 350 (300 HP) small block bare 4-bolt main , cast 3970010 (the famous '010' block), #V0615CRE (Flint, MI); also a set of #3973487X 1.94"cylinder heads ('71-'72), plus an '1182' forged steel crank (10/10), set of SBC 400 conn. rods, a NEW balancer. will this fit?
Old Jan 17, 2011 | 01:19 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Re: 305 to 350 help
The only spec there that determines whether or not it will fit is the block casting number. Don't worry, that block will fit just fine, I'm running the same one. Like I said above, just use the same clamshells that are currently mounted to your 305 block. Just curious, are you building a 350 or a 383?
Old Jan 17, 2011 | 02:40 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The 1182 is a decent forged crank. The rods aren't worth anything to your build unless you put in a 3.75" stroke crank.
The heads have large chambers and would require domed pistons to keep compression up. You'd probably be better served to sell the rods and heads to buy some decent heads with smaller chambers.
Is the damper neutral balanced, or weighted?
Old Jan 17, 2011 | 11:07 PM
WhyNot'87's Avatar
Car: 87 Camaro
Engine: 383 Stroker
Re: 305 to 350 help
im building a 350, i wouldn't mind a 383, but it just more money i dont have
Old Jan 18, 2011 | 09:11 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: 305 to 350 help
if you're going carbed and eliminating the computer controls, the entire passenger side harness can come out of the vehicle; the guages will be coming from the C100 connector on the driver side. Depending on your needs, you may be able to depin some of what's there as well. Highly recommend grabbing a Helms manual if you're going to go that deep into the wiring - it'll definitely make some of the headaches a bit smaller
Old Jan 18, 2011 | 10:58 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Re: 305 to 350 help
Yours might be different, but on my 92 RS, I had to leave quite a few wires intact on the passenger side harness. The wires for my blower motor and a few others that I can't remember right now are in that harness. I used my 92 shop manual to trim out the unneeded wires.
Old Jan 18, 2011 | 11:35 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: 305 to 350 help
those wires a a completely separate harness that comes out from the firewall in the engine bay (centered, but slightly toward the passenger side). the harness that leads to the fender well is only for the engine controls/ecm
Old Jan 18, 2011 | 02:47 PM
WhyNot'87's Avatar
Car: 87 Camaro
Engine: 383 Stroker
Re: 305 to 350 help
wiring is always the fun part we all love to do, right guys?
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
