How to spend $1500? seeking engine advice
Old Sep 21, 2010 | 08:55 PM
Camarillo's Avatar
Car: 1990 RS Camaro
Engine: 1990 305 tbi lo3
Can I swap in a better engine with $1500?
I will do all the installation labor
I have a tired 305 LO3 in my 1990, automatic Camaro
I need to replace it or swap in something else
I want to maintain being smog legal for California
I cannot custom burn/ program computers (way over my head)
I have 30,000 miles on a rebuilt 700r4 with shift kit
I have $1500 to play with...suggestions?
I researched the 5.7 tbi caprice upgrade but blocks seem way over budget, but I am willing to swap in the caprice computer and chip.
Help.
John
Old Sep 21, 2010 | 09:16 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: How to spend $1500? seeking engine advice
the TBI 5.7L is not way over budget if you do it with a good used salvage yard engine, and is looking like your only hope. The Caprice version did get roller lifters, but since your LO3 already has a set, you can start with any '87-up truck 350. Around here, those go for under $200, complete, from Pick-N-Pull. You do need the Caprice computer for the emissions sniffer testing, but you can use the truck injectors.
This leaves you money enough for Vortec heads, the GMPP Vortec TBI intake manifold, a GMPP RamJet 350 cam or an LT1 cam. If you don't already have headers, y-pipe, 3" cat, and cat-back, then you'll have to go with used Vortec 350 heads. And you'll want to get a better axle ratio, if you haven't already. Your car was built with 2.73:1 gears, but all the '85-'92 v6 / auto F-cars were built with 3.42:1.
The RamJet350 cam is better for 2.73:1, the LT1 cam is better for 3.42:1
You won't need a custom tune if you get an AFPR.
Old Sep 21, 2010 | 09:56 PM
Camarillo's Avatar
Car: 1990 RS Camaro
So I found a 350 complete with tbi listed as:
88-95 Gm 350 Motor 4-Bolt Fuel Injct Roller Cam All Complete Runner
with power steering pump and various wires
$850
this is a truck motor with belt driven fan.
can I just pull the water pump and put my regular, non-fan water pump on from my 350?
would a caprice computer and chip make this run nice?
Old Sep 21, 2010 | 09:58 PM
92FBirdVert's Avatar
Car: 1992 Pontiac Firebird Convertible
Engine: 5.0 TBI
try to find yourself a 350 tpi
Old Sep 21, 2010 | 10:32 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
For $1500 you can buy a parts iroc here in cali for about $1300 if you liked too i can look one for you.
Old Sep 22, 2010 | 12:18 PM
chesterfield's Avatar
Car: Pontiac
Originally Posted by Atilla the Fun
This leaves you money enough for Vortec heads, the GMPP Vortec TBI intake manifold, ...
Here in CA he'd be running a huge risk that he wouldn't pass visual emissions inspection. can't swap truck motors into passenger cars. = no vortecs. I'm all for lying to the smog techs but that intake manifold with the plumbing for egr is a dead giveaway.
Old Sep 22, 2010 | 03:26 PM
Camarillo's Avatar
Car: 1990 RS Camaro
the trucks do not have EGR? Chesterfield, is this what you are saying?
Old Sep 23, 2010 | 09:13 AM
Car: Pontiac
on the gmpp tbi vortec intake the egr is plumbed into the exhaust manifold from the intake right up front. any smog tech familiar with chevy engines would spot that it doesn't belong on a passenger car.
if I was you and trying to get an engine on a budget, i'd start checking out pick your part in sun valley.
http://www.pickyourpart.com/
1/2 price sale oct. 8-11
complete engine $112.50 + $25 for computer.
make sure you can tell the difference between 5.0 and 5.7.
Old Sep 24, 2010 | 12:16 AM
Camarillo's Avatar
Car: 1990 RS Camaro
1991 Caprice 9C1 donor car? good idea?
If I bought a 1991 caprice 9c1 car, would it give me everything I need
is transmission same?
Old Sep 24, 2010 | 08:48 AM
Car: Pontiac
That would be a good choice for a donor....except that the one's I've seen in junkyards are generally worn out, high mileage cars. if you found one in that was in good shape but recently wrecked you would have what you need.
I'd guess that the trans is the same but I couldn't say for sure, it would need your tailshaft swapped.
Old Sep 24, 2010 | 02:24 PM
DRock89RS's Avatar
Car: 1989 RS,1991 Z28
Engine: TargetMaster 350, L98 350
Axle/Gears: 10 bolt posi 2.73s, and 3.23s
go on craigslist and find a complete engine for ur budget or close. i find 500 dollar engines that are WELLLL worth the cash.
Old Sep 24, 2010 | 02:32 PM
Camarillo's Avatar
Car: 1990 RS Camaro
Ive been watching craigslist like an ocd stalker watching for car/and or parts, but not too much luck so far
Old Sep 24, 2010 | 04:58 PM
DRock89RS's Avatar
well you might have to go outside your normal location. sometimes its worth the drive lol..
Old Sep 24, 2010 | 10:13 PM
Camarillo's Avatar
Car: 1990 RS Camaro
85 tpi corvette
Would an 85 tpi corvette be a good donor car? can u use a 90 tpi computer to control this?
Old Sep 24, 2010 | 11:42 PM
Car: Pontiac
Personally, I wouldn't bother with any non-roller block unless it was an absolute steal. There's just too many roller blocks available out there to settle for less. If you're not comfortable around junkyards then you're going to spend a lot more money on it than I would. Don't rush into a hasty decision.
My advice: If you don't yet have headers and exhaust then take care of that first and in the mean time keep shopping for a deal. If you stick with TBI it will be easier to stay on budget and get it through smog.
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
E Rod
Aug 28, 2015 05:17 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
