new engine build
Old Oct 19, 2010 | 07:51 AM
  #51
Big Dog Chevy's Avatar
Car: A lot and 86' Z28 and 88' Camaro
Engine: 305, 383 and 565
Transmission: 700R4, th400 and 4L80
Axle/Gears: Frd 8.8 /3.27 and S60
Re: new engine build
Well if you get arp main, rod and head bolts you should be fine. RPMs, heavy/lean doses of NOS and boost with bad tunes kills most engines. You will be fine for the hp you will have but if you have the extra coin go ahead and get some fored parts. FYI Diggler went low 9s on stock LT1 rods and crank and that 92' is doing 10s with a stock crank and rods. imo
Old Oct 20, 2010 | 09:10 AM
  #52
87RSMAN's Avatar
Ill keep it in mind when the time comes to pick insides, I was looking at an eagle kit so far. So far no luck finding a roller block either
Old Oct 20, 2010 | 01:33 PM
  #53
87RSMAN's Avatar
http://www.summitracing.com/parts/ESP-B13402E030/
Old Oct 21, 2010 | 02:52 AM
  #54
Grumbles's Avatar
Car: 1978 Chevrolet impala
Engine: 350ci 300hp/356tq pace crate
Axle/Gears: 3.42 Yukon posi
Got my 88 poncho emissioned with an edelbrock carb swap and passed fine. Right now in PHX if it's newer than '80 they will not perform a rigorous visual inspection to look for egr goodies, they just want you to pass the sniffer.
No idea if this is changing or not, it's just what I dealt with when I was there, just so you know. Also, you can fill out the information informing them of the swap. Or...you could not... just saying.
400 bucks is a really low budget. Save your cash, or surf craigslist for a motor/700r4 tranny combo. They can be found out here, but it's slim pickin's. Don't think I'm attempting to dissuade you, but I'd say set aside 2 grand for the whole deal. A junkyard 350 and transmission probably wont cost you nearly that much all told, but it's nice to have some cushion money to pick up bits and pieces with, especially if this is your first swap.
Fuel injection will need the harness too. Trying to make one talk to the other or just kinda haphazard guesswork is a nightmare waiting to happen. On the other hand, carb is easy, but harder to dial in just right and less driver friendly, also harder to be sneaky about that big shiny double pumper under the hood.
**EDIT** noticing your other post, yeah, a roller block is tough to spot here in AZ, Most of the cars in the JY are crappy minivans or beat up 80's smoggers. If you're willing to settle though, find a 4 bolt main out of an 80's truck. A flat tappet wont be as quick as a newfangled roller, but f/t sticks are muuuuch cheaper and you can still make plenty of power out of a f/t mill. Not to mention if you put a more aggressive cam in you get a lovely lumpy nasty sound .
Old Oct 21, 2010 | 09:28 AM
  #55
Flat tappet cams Will not make the same hp/trq with the same size cam as a roller due to the nature of it's limits. To make the same hp you would have to have a more aggresssive Flat tappet cam that would hurt you on the smog testing. Lope is overlap and that means more hydrocarbons coming out. Also you run a higher risk of killing lobes on flat tappet cams. The only plus I see a FT block has over a Roller one is the cam/lifters are cheaper. But for perfomance roller rule hands down. FYI you can get roller cam blocks out the yards down here for $200 if you pull it yourself and roller short blocks for $350 at A&A midwest. I get mines for $175. A stock TPI or TBI wire harness goes for $50 if you take it off yourself. If you just have to pass ther sniffer then a set up like that 92' is hard to beat for the price and what it does. imo
Old Oct 21, 2010 | 09:46 AM
  #56
Grumbles's Avatar
No real arguing the superiority of roller over flat. Sometimes it's all you can find though, and if you're looking to do it quick and on the cheap flat tappet will take adequate care of you. BDC is right though, if you go with a new cam, you will need new lifters as well, and the breakin period is much more crucial.
The GOOD news is, even if you **** your first cam up completely, you can probably buy the same one 3 times and still not be out what it costs to get new roller guts. Just gotta put in the time
Cheap Flat
http://www.summitracing.com/parts/LUN-10001LK/
Cheap Roller
http://www.summitracing.com/parts/CCA-CL08-420-8/
Not that either of these are right for what you want, just kinda making an example.
Old Oct 21, 2010 | 09:56 AM
  #57
87RSMAN's Avatar
So set it up as a 92? That'd be speed density right? And a 92 harness? I'm still looking around for a roller block, and I keep reading people pick up l31 heads for under 500 a pair assembled, new, I haven't bee able to find them for under 650-700.
Old Oct 21, 2010 | 10:01 AM
  #58
87RSMAN's Avatar
I have a 4bolt main out of a 79 c10, its a good block 010 020, if I absolutley can't find a roller, ill get the retro fit stuff for my block
Old Oct 21, 2010 | 10:14 AM
  #59
87RSMAN's Avatar
I'm in tucson, so if that's how emissions is done there, I should be alright here
Old Oct 21, 2010 | 12:16 PM
  #60
87RSMAN's Avatar
As for the cam, the one listed is comp cam 08-304-8, but would a hotcam increase performance?
Old Oct 21, 2010 | 01:05 PM
  #61
five7kid's Avatar
Transmission: 4L80E/4L80E
Cheap Flat
Cheap Roller
That's a strawman argument.
The real comparison:
Cheap Flat
Cheap Roller
http://www.summitracing.com/parts/CCA-08-420-8/
Unless an engine has been abused or neglected, you can reuse hydraulic roller lifters. Can't reuse flat tappet lifters.
Yes, but a Hotcam is hydraulic roller.
'87-up trucks usually have roller-capable blocks. Sometimes they are the correct casting, but haven't been machined for the roller stuff. Only way to know is to look in the lifter valley. Of course, if you're starting with a roller-capable block that came with flat tappets, you'll need the lifters, anti-rotation dogbones, spider retainer, cam retainer plate, and the shorter pushrods used with the roller lifters.
Old Oct 21, 2010 | 01:09 PM
  #62
Yup it is speed density. I just got the car back in the shop yesterday. Getting it ready for some grudge matches. you can use any TBI harness, you should be able to find them a dime a dozen. As for the heads we get thos for $50-$100 bucks out the yard then put $200 into them after a mild port job.
Old Oct 21, 2010 | 01:19 PM
  #63
You also had the big cars that came with the 5.7 roller blocks but they are two bolt mains. The 4 bolt caps can be bought for $60-$80 bucks and then the machine shop can do the rest. Five7Kid is right about re-using the stock roller lifters, that's what I did with that 92'. Just took them apart cleaned them and re-used them with the new cam. And you can get stock replacement roller lifters from the auto parts store for $30 -$40 a set.
Old Oct 21, 2010 | 01:21 PM
  #64
87RSMAN's Avatar
Well if I can't find a roller block in time, ill buy the stuff to make it roller capable. I wonder what kind of performance gains id see with a hotcam over the one specified
Old Oct 21, 2010 | 04:00 PM
  #65
You have to remember, A block that came from the factory with a flat tappet cam must used the retro cam, lifters and pushrods which will cost a lot more than factory roller stuff. Example, chevy oe roller lifters for roller block at Summit are $120. Retro roller lifter for a non roller block are $490 plus the matching push rods.
Hot cam might give you 20-25 more hp up top as long as the intake system you use can keep up. imo
Old Oct 21, 2010 | 04:16 PM
  #66
five7kid's Avatar
Originally Posted by Big Dog Chevy
You have to remember, A block that came from the factory with a flat tappet cam must used the retro cam, lifters and pushrods ...
Not completely accurate. As stated above, many (perhaps most) '87-later trucks had the roller-type block casting that were machined for the roller provisions, but had flat-tappet cam/lifters. If it has been machined, you can put the roller parts right into it. In fact, I used '87 LB9 roller lifters et al in the ZZ3 shortblock I got back in '05.
If you get an older block ('86-earlier) that predated the factory roller lifters, then, yes, you need to use retrofit roller lifter parts. If that was the case, though, I'd stick with flat tappet (unless building an all-out race engine).
Old Oct 21, 2010 | 05:52 PM
  #67
87RSMAN's Avatar
I'm gonna use the sd vortec tpi manifold, large tube runners stock plenum, but I want to siamese them, and the l31 vortec heads, ported too. I think that'd keep up with a hotcam
Old Oct 21, 2010 | 06:07 PM
  #68
87RSMAN's Avatar
So if I find a block out of an 87 or up chevy, it'll be roller ready? or do I need to look for special casting numbers
Old Oct 21, 2010 | 06:23 PM
  #69
five7kid's Avatar
Okay, once again: '87-up will be the roller type casting, but it may or may not be machined for the roller lifter parts.
Old Oct 22, 2010 | 09:41 AM
  #70
87RSMAN's Avatar
Ok thanks for clearing that up
Old Oct 22, 2010 | 11:07 AM
  #71
You are right about that.
87RSman call up some junkyards or check on ebay to see if you can find a roller block. It seems like you want power and this is your chance to get it right.
Old Oct 22, 2010 | 01:44 PM
  #72
87RSMAN's Avatar
Will do, there are some good ones around here, I've had to shop before. But it sounds like finding one is hit or miss, how exactly would I ask for one or find one, say if it were a full motor they had to offer. Are there specific chevy I could find a 350 roller in
Old Oct 22, 2010 | 01:48 PM
  #73
87RSMAN's Avatar
Off topic, I re did my headliner, it was dirty grey and hanging in places. It turned out great for my first time
My girlfriends 13 year old cousin helped, he's in the background, him seeing me working on my car inspired him to start saving for a 'maro
Attached Thumbnails new engine build-img_20101011_085524.jpg   new engine build-img_20101011_102427.jpg   new engine build-img_20101011_105208.jpg
Old Oct 22, 2010 | 03:18 PM
  #74
Later model 5.7 Roadmasters, Caprice, Pickup trucks, 5.7 vans etc. You can start buy looking at the valve covers, you want the center bolt ones then the casting number. You could tell them you want a roller cam short/longblock. If not check how much it would be to ship from South holland IL. to your place and you can get one from me. lol
Old Oct 22, 2010 | 04:09 PM
  #75
87RSMAN's Avatar
That's an interesting proposition haha, do you have a roller block
Old Oct 22, 2010 | 04:15 PM
  #76
I can get them all day long around here. But right now all i have is a 400, two 305s, and one solid roller 383 that I just sold.
Old Oct 22, 2010 | 06:54 PM
  #77
87RSMAN's Avatar
Well, if you come across a good one pm me, I might have to take you up on it.
Old Oct 31, 2010 | 10:01 PM
  #78
FYI, I had that 92' in my shop all week working on the tune, change the radiator and added some trick shift trans fluid. Went to the dyno yesterday, new numbers are 408whp and 406wtrq with the converter locked. Had to turn the fuel press up to 60psi cause the 35 pounders were maxed out. Just got in from the track where we were fighting traction problems, only was able to run 12.0 at 112mph on a 1.66 sixty.
Old Nov 1, 2010 | 01:39 PM
  #79
87RSMAN's Avatar
That's not bad, that was the first build you posted here?
Old Nov 1, 2010 | 03:32 PM
  #80
[quote=87RSMAN;4722406]That's not bad, that was the first build you posted here?
Yeah that was that 92' RS. Those injectors are too small now so he needs to get bigger ones and some better tires. The car was faster with less power cause it was able to hook up better. Spun in first and 1-2nd shift pretty good.
Terrell351
Jun 13, 2021 01:13 PM
italiano67
Dec 11, 2016 09:21 AM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Jake_92RS
Aug 11, 2015 10:39 AM
