V6 V8 K-member differences?
Old Oct 16, 2010 | 11:17 AM
skinny z's Avatar
Problem solved.
Old Oct 19, 2010 | 05:17 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: V6 V8 K-member differences?
Hmmm, how do you solve a non-problem???
Old Oct 19, 2010 | 05:27 PM
TheMonster's Avatar
Car: 1983 Z28
Engine: Forged 355
Is there a difference?
Old Oct 19, 2010 | 05:34 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
nope
Old Oct 19, 2010 | 05:55 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
unless its a manual car... but they are interchangeable so it doesnt really matter
Old Oct 19, 2010 | 06:38 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
really? whats different?
Old Oct 19, 2010 | 06:56 PM
TheMonster's Avatar
Car: 1983 Z28
Engine: Forged 355
I forgot about you! How is the Camaro coming along?
Pocket's Avatar
Car: 91 Trans Am
K-member is the same, trans crossmember is not
Old Oct 19, 2010 | 06:58 PM
Pillsbry10's Avatar
ha ha ha sorry, i read that 100% wrong...yeah they are the same lol
Old Oct 19, 2010 | 07:57 PM
skinny z's Avatar
By seeing the obvious and that there IS an up and a down on the chassis mounts. Seems no matter which way I placed the mounts on the k-member, I could not get three holes to line up the drivers.
Until the last time I tried it. Presto!
I probably shouldn't be spending so much time in the garage.
Long story short, V8 mounts are in.
Thanks.
Old Oct 19, 2010 | 08:12 PM
skinny z's Avatar
Old Oct 19, 2010 | 08:16 PM
Pillsbry10's Avatar
Thanks.
man when i changed my v6 mounts for new ones it was a huge pain to do by myself and i didnt want to take apart anything else to do it. an extra set of hands on the top side made a huge diffrenece, and turning the bolts upside down
Old Oct 19, 2010 | 08:26 PM
skinny z's Avatar
I've managed to work on my technique and don't find it such a problem anymore.
I've used epoxy to fix the washers to the nuts and sometimes even glue the nuts to k-member using a fish wire to pull the nut up from the inside. Mostly it's just an offset box wrench (with the nut) into the access hole and dropping the bolt in from the topside.
There are other jobs I'd rather do though.
Old Aug 5, 2022 | 12:41 PM
9trillometer's Avatar
hey im doing v6 to lt1 swap, which mount and clamshells did u use?
69GTOby
Apr 18, 2016 02:34 PM
Mdenz3
Sep 17, 2015 08:36 AM
Numbah-1
Sep 12, 2015 08:57 PM
J.C. Denton
Sep 8, 2015 05:35 PM
greenyone
Sep 2, 2015 03:39 PM
