L69 to 1/2 L98
Old Oct 19, 2010 | 10:16 AM
marcopasco39's Avatar
Car: '84 Trans Am
Engine: L69 stock
Transmission: T-5 B-W
L69 to 1/2 L98
I'm getting an L98 from an '89 IROC and want to put my L69 heads on it w/ the intake and Q-jet. I would need the 350 knock sensor but other than that I think I should be good right? Any ideas for a cam upgrade? or could/should i use my L69 cam too? Any suggestions much appreciated
Old Oct 19, 2010 | 02:03 PM
Doom86's Avatar
Car: '86 Z28, '91 RS
Engine: 305ci, 305ci
Transmission: TH200c (no kidding), TH700r4
Axle/Gears: 2.73, 2.73
Re: L69 to 1/2 L98
Why do you want to put 305 heads on it? The Iron L98 castings are pretty decent for the era.
Is your L69 year 84? If so it's a flat tappet block with perimeter bolt heads. The L98 is a roller tappet block with center bolt heads. Don't waste the good roller potential with flat tappet, that's going backwards.
IMO use the L98 heads, get a Qjet intake for center bolt heads, and a XR264 cam with accommodating valve-train goodness.
Old Oct 19, 2010 | 06:57 PM
Pocket's Avatar
Car: 91 Trans Am
Re: L69 to 1/2 L98
Or figure out the wiring and keep it injected
Old Oct 19, 2010 | 07:06 PM
83C_CamAroZ28's Avatar
Car: 1983 Z-28
Engine: 5.7 L
Re: L69 to 1/2 L98
im looking for the l69 heads if u dont end up using them...let me kno...
Old Oct 20, 2010 | 06:36 AM
Car: '84 Trans Am
Engine: L69 stock
Re: L69 to 1/2 L98
the L98 doesn't come with heads. I would think my heads would raise compression a bit.
Old Oct 20, 2010 | 01:43 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
They will. Thick composite head gaskets instead of steel shim will lower it back down to L98 range, though.
Old Oct 20, 2010 | 03:04 PM
Doom86's Avatar
Re: L69 to 1/2 L98
They would raise it a lot since it has NO compression now.
Use the 416 heads then and if you have the funds for the valve job put bigger valves in. If you also have the tools/funds/skill/patients port them to make best use of the larger valve and that would be the biggest gains.
91chevyz28
Feb 10, 2022 07:58 PM
FormulasOnly
Jul 23, 2018 08:47 AM
PurelyPMD
May 5, 2016 04:57 PM
gord327
Sep 29, 2015 10:18 PM
romcjr
Sep 17, 2015 05:18 PM
