big block solid engine mounts?
Old Oct 27, 2010 | 08:13 PM
Jake88maro's Avatar
Car: 88 camaro, 87 TA
Engine: 454 stock, built 468 400hp+150 shot
Transmission: WC t5, m29 t56 spec stg3 clutch
Axle/Gears: 9 bolt 2.77, 9 bolt 3.70
i'm doing a big block swap on my 88 camaro. i decided to go with the solid motor mounts since the motor was obviously out. well the guy at summit said they were same height as the stock 305 mounts, and the guys on here who've done this swap use the stock 305 ones. for some reason the k member will not allow the engine to slide in. like the pan is hitting the k member. any ideas? thanks alot
Old Oct 27, 2010 | 10:01 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: big block solid engine mounts?
The pan shouldn't hit the k-member with any engine mounts. Many times it's just hard to align the mounts to drop the engine down onto them. Take the transmission out if you have to then reinstall it after the engine is in place.
Old Oct 28, 2010 | 12:40 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
BBC and SBC use the same motor mounts in these cars.
Old Oct 29, 2010 | 07:28 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
My last car was ended up a BB,this one eventually will as well.I remember pan clearance being tight,but I don't think the solid mounts are your trouble.
I'm betting that you have a truck style oilpan on your BB.WILL NOT work,learned that lesson the hard way myself.You need a Chevelle style pan,not the only car with this pan,but I know the one I used was off of a Chevelle.
Hope that helps.
Old Oct 29, 2010 | 08:11 PM
92 BBC Z's Avatar
Car: Currently have 3 cars and 1 truck.
Engine: 1970&92 Cams,both BBC's
Transmission: LS1 T-56 & PG w/vendor's
Axle/Gears: Built 10 bolt& 9inch w/spool
Are you sure your mounts are in the correct position? Your factory K-member should have two pair of mount holes, one pair for v-6 cars located aft on the member and v-8 cars located forward on the member. If its not set for the v-8, it'll only be off by a few inch's, but never fit.
Old Oct 29, 2010 | 08:33 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Here's some info from the findings by
Atilla the Fun--
https://www.thirdgen.org/forums/engi...k-oil-pan.html
Hope there's something there you can use too
Old Oct 31, 2010 | 04:26 AM
Air_Adam's Avatar
I used the '70s style truck pan in mine and it worked fine.
Old Nov 4, 2010 | 06:46 PM
Jake88maro's Avatar
hey thanks alot guys i picked up the chevelle oil pan and it did the trick.
jhawkeye
May 25, 2022 06:33 PM
sreZ28
Aug 14, 2015 07:48 PM
Zachattack0925
Aug 12, 2015 09:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Elliswon
Aug 10, 2015 12:33 PM
