BBC
Old Nov 5, 2010 | 02:55 AM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
BBC
Has anybody discovered any manifolds that will fit with a BBC in the third gen? My buddy insists he was able to get a set to clear the frame rails without modification... he no longer has the car but I heard many stories and saw pictures of it and they were defiantly manifolds.
I currently have the motor back outta the car to change cam (yet again) and do valve seals on the new heads. I refuse to spend $800 on headers and if I can't find manifolds that work I will be putting the motor into a Z71 to spank the local imports.
Old Nov 5, 2010 | 11:10 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: BBC
i don't think you'll be able to get anything to be drop in and go, but here's a start:
https://www.thirdgen.org/forums/engi...-454-swap.html
Old Nov 5, 2010 | 11:16 AM
tater's Avatar
Car: Dad's 87 Bird (Org Owner)
Engine: Vortec 350 Crate Motor
Transmission: TH350
Axle/Gears: 3.42 Posi
Re: BBC
Why are you changing the cam again? Did you wipe out a lobe?
Old Nov 5, 2010 | 07:57 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Re: BBC
Thanks those manifolds at least clean the frame rails.
And as far as the cam goes, I had the heads ported some I'm running a slightly more aggressive cam.
Old Nov 11, 2010 | 05:47 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: BBC
From what I remember, the 'car' manifolds (Chevelle, camaro, etc) will physically clear the frame rails, but the exits are too close to the firewall to bolt an exhaust pipe to them, so they won't work either.
BBC is a pay-to-play swap... I did one myself.
Old Nov 11, 2010 | 08:02 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Re: BBC
Would it be possible to beat the firewall back to make it bolt up? It doesn't really matter anymore I sold the motor and car but I'm still curious.
Old Nov 11, 2010 | 08:08 PM
Air_Adam's Avatar
Re: BBC
Na, because the mounting flanges angle back, they dont point down. You'd have to bash it in about 3-4" to make it work.
Old Nov 12, 2010 | 02:38 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: BBC
Has anyone tried the late-model (IIRC- 3800?? 8.0 Ltr??) truck manifolds??
In pics, it **looks** like a straight down flange out of #7 & 8.
There aren't any in the jy here.
Expensive for **new** ones going as much as 400+ EACH!!
I don't recall the site off hand, I believe Dorman made them.
Old Nov 12, 2010 | 05:26 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Re: BBC
I think the new 8.0 has a different design in the head. I doubt it would bolt up.
EDIT - wrong button. Post is untouched.
Old Nov 12, 2010 | 10:01 PM
Car: '87 Camaro
Re: BBC
Thanks zraffz--
Old Nov 12, 2010 | 11:33 PM
Air_Adam's Avatar
Re: BBC
You sure? I know the intake side is different, but I don't think the exhaust side is different....
Loudnproud86
Jul 14, 2016 12:59 AM
redformula88
Oct 14, 2015 06:08 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
vortec tpi
Sep 26, 2015 08:14 AM
vortec tpi
Pacific Northwest Region
Sep 26, 2015 08:13 AM
