1992 camaro 3.1 to 5.7
Old Nov 12, 2010 | 11:45 AM
camaro55555's Avatar
The is a 1992 camaro for sale in my area and I would like to but it. $1500 v6, 5 speed, but needs a starter. The v6 is to small for me and I would like to put a 5.7 350 in it. I know it was not an option in 1992 so will this even work? How much should I expect this to cost. I have a friend that will help me so there will be no labor cost. I read the sticky on v6 to v8 but I am unsre what exactly bolts onto the engine being that this will be my first swap.
Thanks!
Old Nov 12, 2010 | 05:36 PM
AmorgetRS's Avatar
Re: 1992 camaro 3.1 to 5.7
Buy a Camaro with a V-8 already in it. In 1992 you could get a Z28 with a 350.
Old Nov 12, 2010 | 05:54 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Emission passing or no? If it's not passing emission you can do it for next to nothing and in little time. It can cost you anywhere from $300-$+++++++ depending on what you build lol.
Old Nov 12, 2010 | 06:07 PM
Anything after 1995 in MA does not need to pass emissions. Third gen canaria with 5 speeds are rare in my area especially with v8
Old Nov 12, 2010 | 06:10 PM
1986chevycamaro's Avatar
Car: 92camaro,86 camaro
Engine: 355
i just got a 92 for 250 with out motor or trany and i put my mild 355 and 700r4 into it. as in right now i probably got other 200 in parts
Old Nov 12, 2010 | 06:11 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Yeah... well the 5 speed sucks. I thrashed one at the track behind a budget build 350. Lost 2nd and 3rd in the same day.
Old Nov 13, 2010 | 02:43 AM
Dartht33bagger's Avatar
Car: 1991 Z28
Engine: L31-R 350 w/ EBL P4
I'm so jealous of you...anything made after 1975 here has to pass emissions
Old Nov 13, 2010 | 07:48 AM
I have not worked with engines before but my friend has. The sticky on v6 to v8 said everything that bolts on needs to be replaced. What exactly bolts on?
Old Nov 13, 2010 | 07:53 AM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Entire belt assembly, motor mounts, uh if you change to a carbed motor you gotta change the fuel pump or run a regulator.
Old Nov 13, 2010 | 10:01 AM
Engine: 355
you need new motor mounts cuz they the v6 are smaller and wrong location if i was you i would buy new ones they are cheap i got mine from napa think they are little under 15 bucks
92camaroJoe
Jul 29, 2023 07:57 PM
Vintageracer
Jan 10, 2020 05:33 PM
92camaroJoe
Aug 13, 2015 06:07 AM
