87 corvette engine
Old Nov 10, 2010 | 12:56 PM
bigj350's Avatar
Car: 88Fbird,88Formula,04 GP,04 Durango
Engine: LO3,L98,3800,HEMI
Transmission: 700r4, 4l60e, 545rfe
87 corvette engine
I found a 350 TPI out of an 87 or 86 corvette for $1500. Comes with the computer and wiring. Its runs and is currently in a wrecked corvette. I want to put it in my 88 formula which is a 305 TPI. That should be a direct swap, am I correct? Thanks
Old Nov 10, 2010 | 01:36 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 87 corvette engine
More or less. There are no crossover passages in L98 heads, so you won't have EGR.
Old Nov 10, 2010 | 01:43 PM
thewizard's Avatar
Car: LT4 C4, LT1 CE, 95' Dyno Air
Transmission: ZF S6-40, 4L60E, sprockets
Axle/Gears: 3.45, 3.07
^ I thought Vettes used an external EGR setup?
Old Nov 10, 2010 | 01:46 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
They do, but that won't attach to a thirdgen exhaust directly.
Old Nov 10, 2010 | 01:55 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Hmmm, it's been several years, but a formerly local 3rd gen bud used the Vette stuff with 3rd gen manifolds. I thought.
Old Nov 10, 2010 | 02:34 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
If you swap the LB9 intake base over, you can retain the thirdgen-style EGR. If you use the Corvette base, the EGR will need the pipe from the exhaust manifold.
By the way, $1500 sounds like way too much for that motor to me unless it's got ultra low miles. There's not too much that's special about that motor, especially if it's the iron-head motor.
Old Nov 10, 2010 | 02:35 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The LB9 heads would have to come over too.
Old Nov 10, 2010 | 02:49 PM
Jim85IROC's Avatar
You can slot the bolt holes a little, or just find a stock pre-centerbolt f-body TPI base. They're a dime a dozen.
Old Nov 10, 2010 | 02:50 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I'm worried about the exhaust crossover, not the bolt holes.
Old Nov 10, 2010 | 02:51 PM
bigj350's Avatar
I wouldnt mind keeping the thirdgen intake, but that engine sucked up water its been sitting for 2 years. I wasnt sure how much trouble it would be to clean it up.
I wasnt sure about the price since it comes with the TPI and everything. I have been having a difficult time finding a replacement that has everything with it around my area. I checked out Trans am creations and hawks third gen they were close to the same price plus shipping. Im going go check it out later, hear it run and see how many miles it has.
Old Nov 10, 2010 | 03:53 PM
Jim85IROC's Avatar
Oops. Forgot about that. I keep forgetting that not everybody lives in Vermont where the idea of "emissions compliance" is just making sure that it doesn't make the inspector's eyes water while it's running.
Old Nov 10, 2010 | 04:24 PM
bigj350's Avatar
I forgot to mention, I don't have worry about emissions where I live.
Old Nov 10, 2010 | 05:11 PM
five7kid's Avatar
You said, "a 350 TPI out of an 87 or 86 corvette". Does it have aluminum heads? The early '86 Vettes had cast iron heads with the exhaust cross-over passages.
Even if you can ignore EGR from an emissions-inspection standpoint, the system will set an error code if it isn't seeing an EGR valve response. Plus, the timing tables are based on the EGR functioning, and if you don't change them, you could get light-load pinging.
Old Nov 10, 2010 | 05:45 PM
bigj350's Avatar
I didn't think about that. I was told it has the aluminum heads. I'll just use my intake so i have the egr. If the intake is any good, it might have water damage. Or would those heads even work with my intake?
Old Mar 11, 2011 | 09:34 PM
Diggler86's Avatar
Car: 86 TA
Transmission: 700R4 - 2200 stall
Axle/Gears: 3.42 posi
This link says the vette intake manifold has provisions to relieve hot spots. Would that be a problem using a thirdgen intake on the aluminum heads without this feature?
http://www.hotrodlane.cc/Streetstories/choosetpi1.htm
Old Mar 11, 2011 | 10:48 PM
Diggler86's Avatar
Car: 86 TA
blasted, this just sunk in. would still be no provisions for EGR if using lb9 intake and vette heads.
Old Mar 11, 2011 | 11:50 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Yeah thats too expensive IMO as well.A little more money and you could have you a 5.3 LS engine or a decent crate motor.Both would be more desirable to me and perform better.
Old Mar 12, 2011 | 07:05 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
GM thought it necessary.
Most aftemarket intakes used by alum head L98 Vette owners don't even have a rear coolant crossover ; let alone the steam vent and nobody has reported problems
Old Mar 12, 2011 | 07:08 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
No you won't
Old Mar 12, 2011 | 07:21 PM
bigj350's Avatar
I ended up getting a complete L98 with tranny and harness from an 89 trans am for $800. I decided that corvette engine was way too expensive especially after I saw it.
Frozer!!!
Jan 19, 2024 04:55 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
toronto formula
Nov 10, 2015 06:17 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
milk
Aug 10, 2015 06:26 PM
