PULLING ENGINE AND TRANS TOGETHER ????
Car: white 87 iroc-z
Engine: 5.7 tpi
Axle/Gears: 3:27
Has anyone had any luck pulling a 5.7 tpi engine and transmission together from 87 iroc. The car is on jackstands fully extended, maybe 16 inches off the ground.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: PULLING ENGINE AND TRANS TOGETHER ????
Yup. Thats how most people do it. I find it easier if you leave the front of the car on its wheels, and get the rear of the car as high as you safely can on jackstands.
Engine: 5.7 tpi
Axle/Gears: 3:27
The car is completely stripped except engine and tranny, is it a problem that the wheels are removed?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
no not really, but if you are just using a engine hoist aka cherry picker, the front of the car may be too high to get the engine and trans over the radiator support and out of the car. Its best to have the car at ride height when you pull the engine out the top. A balance bar for the hoist to adjust and level the engine and trans will be a great help too.
Engine: 5.7 tpi
Axle/Gears: 3:27
Thanks guys, i will be using an engine hoist. I will try lowering the front jack stands, and keeping the rear stands fully extended. I was concerned that there wouldnt be enough room to tilt the transmission down if the front of the car was to low.
Car: 86 Trans Am
once the trans comes off the crossmember, it will drop a lot, makes quite a mess too. Maybe consider a large catch pan to catch all the ATF
Engine: 5.7 tpi
Axle/Gears: 3:27
Any suggestions on where to fasten the chains to engine, there are no hooks or any thing on the block or intake manifold.
Car: 84 Camaro
Transmission: 700R4 from 87 Camaro
I installed my own hooks in the intake manifold bolts for removal and installation, then removed them once I set it back in. When I removed my engine and tranny together, I had to put a little bit of weight on the front end to get the engine to clear that last little bit, same for re-installing. It was resting on its wheels.
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
y dont u just lift the car off the motor and trans.. aka just unbolt the k member leaving the motor and trans still attatched.. much easyier if u ask me.. ive done it countless times before..
84z96L31vortec
Aug 20, 2017 12:16 AM
Sanjay
Aug 12, 2015 03:41 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
