355 in a 92, need info please
Old Dec 20, 2010 | 01:50 PM
Badrs2810's Avatar
Car: 91 camaro rs
Engine: 305 (350 vortec in dec.)
Transmission: Wc-T5
Axle/Gears: 3.08 (3.42 in dec.)
Hey guys, I have found an amazing deal on a 355 motor. My question is what is needed to run it in my 92 rs camaro? Will it bolt to my wc t5? Etc. It is a 4 brl Holley carb, so I would be going from (tbi) toilet bowl injection, lol, to carb, please I could use the info, motor is rated at 340- 350hp, thanks.
Old Dec 20, 2010 | 01:53 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
There is a tech article linked from the thirdgen.org homepage about converting from EFI to carb.
The T5 will bolt to a 350. Only question is what type of rear main seal your 350 has, which will determine which flywheel you need.
Old Dec 20, 2010 | 01:57 PM
Badrs2810's Avatar
Car: 91 camaro rs
Transmission: Wc-T5
Re: 355 in a 92, need info please
That's a good question, idk much right now about the motor, it is in an early ninties s-10 and it is bolted to a 700r4 tranny, I believe.
Old Dec 20, 2010 | 06:16 PM
Badrs2810's Avatar
Car: 91 camaro rs
Transmission: Wc-T5
I read up on the efi to carb article, seeing as how I'm pulling the entire complete 355ci out of the s-10 and pulling my motor, the only part I really need to follow would be the fueling system, right? Bc of it being a carbed motor it already has the distributor and intake and carb, well I would also have to follow the throttle cable info and all too, but that should be simple. My question on the fuel pump would be, could I just use my tbi fuel pump and get a regulator, or do I definitely need to get an older pump, a carb pickup or whatever?
Old Dec 21, 2010 | 03:05 PM
five7kid's Avatar
Since S10's never came from the factory with a V8, the engine could be most anything. If you can get the casting # off of the block, that would provide a good deal of the information needed.
You can use the in-tank electric pump with a return-type regulator. The story on a factory TBI pump is it can support about 300 HP on its own. If you use it as a pusher pump to an engine-mounted mechanical (with a return-type reg after the mechanical), it should be able to support more.
Old Dec 21, 2010 | 05:11 PM
Badrs2810's Avatar
Car: 91 camaro rs
Transmission: Wc-T5
Ok, one more thing, I read something bout the key, ignition key, that it has to use the ECM, is that true? Or can I junk it? My key is the key with the little microchip in it, I'm also using factory guages, so what will I have to keep to make those things work?
Old Dec 21, 2010 | 08:00 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
If you don't have a computer ( not needed for carb ) then the VATS ( chip in key ) no longer works.
All you have to do is bypass the starter enable relay that was operated by the VATS
Old Dec 21, 2010 | 08:03 PM
Badrs2810's Avatar
Car: 91 camaro rs
Transmission: Wc-T5
How might I do that?
Old Dec 22, 2010 | 01:19 PM
five7kid's Avatar
There are a couple of tech articles on VATS.
Old Dec 23, 2010 | 01:06 AM
Grumbles's Avatar
Car: 1978 Chevrolet impala
Engine: 350ci 300hp/356tq pace crate
Axle/Gears: 3.42 Yukon posi
What's the consensus on return-style'd in-tank pumps? Living on borrowed time, or will they last?
Old Dec 23, 2010 | 01:37 AM
five7kid's Avatar
If you don't know when your pump was replaced, you're probably on borrowed time.
Old Dec 23, 2010 | 02:48 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Could you please link them up here as Im in the same perdicament as Badrs and am going to be swapping everything from my 85 to a 92 V6 RS as its a milllion times cleaner of a shell than my 85.
3rdgenparts
May 21, 2016 11:50 PM
darwinprice
17
Oct 11, 2015 11:51 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
