stroker swap implications
Old Dec 27, 2010 | 08:00 AM
jacklieb's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: 5-Spd
Axle/Gears: 3:08
I'm in the process of planning an engine swap for 91 Camaro RS from 305 TBI to 383 Stroker. The engine builder says it does not support EGR, so I assume there is not port in the intake for an EGR valve. Is there a way to defeat the EGR logic and/or plumbing that will still pass emissions? The car will be antique by my states definition of the word in 5 years and it may well take me that long to finish bodywork and engine swap so it may be a mute point. Are there any other gotcha's that anyone can prepare me for?
TIA - Jack
Old Dec 27, 2010 | 08:28 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: stroker swap implications
A tailpipe test probably isn't going to be done under any conditions where the EGR would be active. If it's a visual test, you can just bolt up all the EGR plumbing and maybe burn a chip to eliminate the EGR tests.
mhatfield 14
Oct 24, 2015 07:48 AM
Reddeath210
Oct 6, 2015 08:20 AM
Mickeyruder
Sep 2, 2015 02:45 PM
TEEZER TA
Aug 30, 2015 06:35 PM
bdads
Aug 24, 2015 06:01 PM
