motor mounts
Car: 92camaro,86 camaro
Engine: 355
Re: motor mounts
so just came back from parts store and if daz is talking about the motor mounts that mount on the frame bbc and sbc are the same ?
any one know what he is talking about?
any one know what he is talking about? Supreme Member
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: motor mounts
New mounts will raise it if anything, as the new rubber would be stiffer. Solid mounts I think lower a tad, but not alot. I take it you are having hood clearance issues?
Engine: 355
Re: motor mounts
im trying to build my twin turbo set up but i think my turbos are going to be way over the hood i dont mind some over the hood but not all
Car: 1992 RS
Engine: Carbed 350
Re: motor mounts
Not sure there's a hood available for that kind of setup. Even a 6" cowl is only raised in the center for the carb. Of course you could design your own hood as well.
Might rethink the design - there's several folks that have done twin turbo's here, but all the ones I've seen were brought forward where there's space (between water pump and radiator) rather than upwards like yours. Might be better to put the motor in the car, and design within the space available.
Good Luck - and keep us posted.
Engine: 355
Re: motor mounts
i have a 6 in cowl on my 92 and your right the hood wont clear the turbos. i might just cut the headers and make them come forward
ambainb
Apr 25, 2016 09:21 PM
NBrehm
Aug 5, 2015 07:57 PM
