Locating a Distributor washer
Old Jan 20, 2011 | 06:11 PM
SanAntonio3's Avatar
Car: 1988 Camaro Iroc-Z
Engine: 1994-1995 LT1 5.7
The distributor takes a washer in between it and the intake correct? The distributor on the '89 305 I've been working on spins when the bolt is tightened. Im thinking i need this washer. Where can I find one, locally?
Old Jan 20, 2011 | 07:10 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Locating a Distributor washer
Fel-Pro Q70194
Old Jan 20, 2011 | 07:40 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Well, not so much a washer as a gasket. I seem to have oodles of them. Any of your local parts stores should carry the distributor gasket.
Old Jan 20, 2011 | 09:11 PM
EagleMark's Avatar
Yeah but I'm thinking the bolt is to long and bottoming out... is the gasket really thick enough to cause the distributor to spin when the bolt is tightened?
Old Jan 20, 2011 | 09:18 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It's just a paper gasket.
Old Jan 20, 2011 | 09:20 PM
EagleMark's Avatar
Then I would think he got the wrong bolt in there and it is bottoming out before it tightens the distributor.
Old Jan 20, 2011 | 09:21 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
3/8-16 thread... I like using a stud in the hole and a nut to tighten it up, myself.
Old Jan 21, 2011 | 12:14 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Stud with a nut on my engine also. Make sure the hold down clamp is sitting properly on the distributor.
Old Jan 21, 2011 | 07:51 AM
wow. thanks for the quick replies. I'll find a stud or make one. That sounds like a good idea. Thanks
Bohemian
Aug 15, 2017 05:11 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Saxondale
Exterior Parts for Sale
Sep 7, 2015 11:40 AM
Jlanz55
Sep 6, 2015 03:05 PM
tonys91rs
Sep 2, 2015 07:07 PM
