2.8 to 350 Swap
Old Jan 28, 2011 | 03:27 PM
1988thirdgencam's Avatar
Car: 1988 Chevy Camaro RS
Engine: 2.8l
Transmission: M5
2.8 to 350 Swap
I have a 2.8 fuel injected thats working good but I am just wondering is it worth it to put in a built 350 and also will it bolt up to the 2.8 tranny the m5 i believe. If I put in a carbed 350 is this gonna invovle alot of modification to the wiring? and if i buil it to about 350ish horse is that gonna blow the tranny or rearend to peices?
Old Jan 28, 2011 | 04:08 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
First, read the V6 to V8 swap sticky in the top section of this forum. That should answer 90% of your questions.
"Worth it" can't be answered by us for you. What you can be assured is your car will be a completely different animal.
Old Jan 28, 2011 | 05:24 PM
Engine: 2.8l
Transmission: M5
Re: 2.8 to 350 Swap
Ok on a 1-10 scale what would you rate the difficulty. I actually havent driven the car yet i bought it for $500 in pretty good shape but needs clutch, brake pads and shoes, and hydralic steering hose. So the plans are to replace those and then the motor i am thinking of doin a mild cam with about 115 seperation i think with the refurbed vortecs to keep with the iroc theme (even though its an rs)and just make it pretty haha
Old Jan 28, 2011 | 05:33 PM
five7kid's Avatar
Straight six to 350 in a '70 Nova - 1.
V6 to V8 in a 3rd gen f-body - 4.
LS1 in an '86 Fiero - 9.9.
Old Jan 29, 2011 | 01:36 PM
Engine: 2.8l
Transmission: M5
Re: 2.8 to 350 Swap
Really my largest cncerns is will the m5 tranny and my stock rearend hold up to alittle power around where will it hold up good to? I noticed thats the same tranny pn the irocs so im guessing i have alittle play room when it comes to the tranny? am i correct?
Old Jan 30, 2011 | 02:33 AM
five7kid's Avatar
The V6 T5's have a smaller input shaft than the V8 T5's. If you go through the hoops necessary to mount a V6 T5 behind a V8, you'll have to baby the car like it like nobody's business - i.e., drive it like it still has a V6 in it.
The rears are the same, though, whether V6 or V8 (with regard to strength - gear ratios could be different). If you get a transmission strong enough for the V8, the rear will be the next weak link.
Old Feb 1, 2011 | 10:20 AM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
Re: 2.8 to 350 Swap
conventional wisdom says it's easier and cheaper to buy a car that has a V8 in it than turn a V6 car into a V8 car
It depend how much HP you are wanting. If you are looking for around 200, you can get that from a 3.4 with upgrades.
Old Mar 29, 2011 | 03:50 PM
mikeal8208's Avatar
Car: 1991 camaro RS
Engine: 3.4-3500 hybrid + Vortech V1 S-trim
Axle/Gears: 4.11 soon
Re: 2.8 to 350 Swap
The 350 most likely will not bolt in because the 2.8 v6 has a metric bolt pattern... I tried to put in a 1988 1500 350 transmission in my 2.8 when my old transmission went out but it wouldn't bolt up
Old Mar 29, 2011 | 04:32 PM
five7kid's Avatar
The is no "most likely" about it. The V6 bell housing has a different bolt pattern than the SBC.
However, the V6 T5 bolt pattern to the bell housing is the same as the V8 T5 bolt pattern to the bell housing. That doesn't mean a whole lot because of what I said above.
bellez77
Sep 5, 2015 08:39 PM
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
