my dampner wont go on??
Car: 1991 Camaro RS ttops
Engine: 00 383
Transmission: t-5
Axle/Gears: moser 9" 3.50
ok i have a 1973 sbc 400 and im trying to put my new harmonic dampner on and it wont go on all the way. it needs to be about another rib and a half over so the belt lines up right. whats wrong. i have baked the thing to 450 degrees for an hour and used refrigernat to cool the crank to make it colder. and it still wont go on.. and it is the right balancer and the crank is clean and the keys arent smashed
Engine: 00 383
Transmission: t-5
Re: my dampner wont go on??
but its summit's balancer heres the link http://www.summitracing.com/parts/SUM-C4266/ and when i baked it in the oven it bronzed so i doubt i can take it back..
Very common with aftermarket dampers.
You need to hone its bore with a brake cyl hone or the like to get it to fit. You'll find the hone itself doesn't do well; but if you wrap some wet sandpaper around it and lube it with trans fluid, it works pretty good. You'll want about 120 grit or so and it will take a while.
Some (notably ATI) even tell you in their printed instructions to do so.
Engine: 00 383
Transmission: t-5
well i got it fixed i went out and got a trick flow damper and got the install kit with it too and once i heated it in the oven the tool mauybe it sooooo much easier than the dead blow hammer thanks for your responese! now the motor will be in tommorow or wednesday!!
Transmission: 4L80E/4L80E
You were beating on it rather than using a proper damper install tool?
Engine: 00 383
Transmission: t-5
yeah i was heating it in the oven then using a dead blow hammer silly me.. the install tool was soo worth it
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Thats the absolute wrong way to put it on. Never should a hammer be involved in the process. (Unless youre beating it up after romoving it from the car for stress relief)
EDDIETA_ZZ3
Oct 15, 2004 10:04 AM
