v6 to v8 fuel question
Old Feb 24, 2011 | 09:55 PM
adam85z28's Avatar
Car: 84 Sport coupe
Engine: chevy 350
My car is a 84 sport coupe and it had a v6 in it and i believe it was a stock carb 2bbl and it was a stick with 3.42 gears the v6 is long gone its just been sitting few questions
1 did these cars have in tank pumps just like fuel injected carbs?
2 if so is it the same pump ?
3 and if it is do i just use a regulator and return line to feed my v8 carbed ?
if not what do i need to do ?
i know theres a swap thread but ive never found anything about v6-v8 both carbed
Old Feb 24, 2011 | 10:01 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: v6 to v8 fuel question
1984 should not have a pump in the tank - just attach your manual fuel pump to the new motor and run that fuel line to your carb.
Old Feb 24, 2011 | 10:04 PM
adam85z28's Avatar
Car: 84 Sport coupe
Engine: chevy 350
ok one issue why do i have a return line as well than ?
Old Feb 24, 2011 | 10:14 PM
Car: 1992 RS
Engine: Carbed 350
I assume the mechanical pump on the block uses a return line to regulate pressure. I'm not 100% sure - but I'm pretty sure no 1984 car with carb had any helper pump in the tank, think those started in 1986 & 1987. If you had an electric pump in the tank, you'd hear it whine or hum when you turned the key to on - stick ear to tank and listen while someone turns on the key.
Old Feb 24, 2011 | 10:32 PM
adam85z28's Avatar
Car: 84 Sport coupe
Engine: chevy 350
alright makes sense ill take a look the carpet is out if theres no pump wont i have less wires going to the tank as well ? (car is not set up to have a battery in it whole front is stripped for paint)
also i want to switch to braided lines and an fittings can anyone show me what i need ?
Old Feb 24, 2011 | 11:08 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
In a factory-type 3rd gen mechanical fuel pump, the pressure is regulated by a relief valve built into the pump that sends excess fuel volume back to the tank.
It helps reduce vapor lock.
Old Feb 24, 2011 | 11:11 PM
adam85z28's Avatar
Car: 84 Sport coupe
Engine: chevy 350
so really i could do an in line pump and than use the other line for a return i want to run nitrous so im thinking ill need higher flow to feed the wet nitrous system or will a block mounted mechanical unit work ?
Old Feb 25, 2011 | 02:49 PM
five7kid's Avatar
How big of a shot?
Most serious nitrous set-ups use an electric pump to get smoother fuel pressure. A mechanical pump pulses with every-other engine rotation. A small shot (and I'm not willing to give you an exact number to what "small" means) could probably live with a mechanical pump.
Personally, I'd convert to an in-tank pump with plenty of capacity such as a Walbro 255. But, you could do in-line if you like. Use a return-style regulator such as the Mallory 4309, and the stock return line.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
fasteddi
Sep 2, 2015 10:29 AM
redmaroz
Aug 16, 2015 11:40 PM
