Engine Wiring Harness Removal
Old Feb 8, 2011 | 03:44 AM
caffeine's Avatar
Car: 89 Firebird Formula
Engine: 3500T
Axle/Gears: 9 bolt/4.11
Hi. I've gotten all of the engine wiring harness removed except I can't figure out how to disconnect it where it goes through the firewall on the driver's side. There's a photo of it attached
Old Feb 8, 2011 | 12:24 PM
shan89's Avatar
Re: Engine Wiring Harness Removal
there is a bolt in the center of it if you peel back the cover you can barely see it but its in there
Old Feb 8, 2011 | 05:06 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
And the bolt doesn't come out - you have to loosen the bolt and gradually pull back on the connector until both disengage.
At least that's what mine did...
five7kid's Avatar
Out of curiosity, why do you want to remove it?
Old Feb 8, 2011 | 05:18 PM
caffeine's Avatar
Engine: 3500T
Thanks so much for your help. Once I knew where the bolt was it was simple. I'm installing an LT1 and I've sold this wiring harness with the old engine.
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
Reddeath210
Oct 6, 2015 08:20 AM
jharrison5
Aug 19, 2015 05:53 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
3rdgenparts
Aug 8, 2015 07:09 PM
