4 inch stroke with stock K-member
Old Feb 13, 2011 | 08:52 PM
90camaro383's Avatar
Car: 1990 Camaro wide body
Engine: 421 Dart SHP SBC
Axle/Gears: 3.73 Eaton
I'm debating over running a 4" (434cid) stroke or a 3.875" (421cid) stroke with a 4.155" bore on a after market block. The main problem is the oil pan clearing the stock k-member. Has any one ever had a 4" stroke with a stock k-member. If so what part number for the oil pan? An is it really worth the extra machine work and price for the oil pan just for 13cid?
Old Feb 13, 2011 | 09:04 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Re: 4 inch stroke with stock K-member
Its the characteristic of the 13 cubes youll like.
A 421 will keep you plenty entertained though.
All 23 deg. stuff?
Old Feb 13, 2011 | 09:08 PM
AutoRoc's Avatar
Engine: Vortec 4200 Inline 6 PT70 Turbo..
Transmission: 4L65E
Putting money into the intake/heads/valvetrain/carb is more important in my opinion. I ran a 3.875" eagle crank, stock block, and Canton oil pan for our 82-92 f bodies. Fit nice.
Goodluck!
Old Feb 13, 2011 | 09:34 PM
Yes every thing will be 23 deg., hydraulic roller cam, Full roller rocker arms.
An the Canton oil pan (15-244 - SBC F BODY RR) Was the one I was looking at. An the other truth is I'm going to be running dish pistons for now. So in the future I can add a Weiand 177 supercharger.
Street Lethal
Apr 30, 2019 12:14 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Randomtask2
Aug 13, 2015 01:57 AM
Exxon Limited
Aug 9, 2015 08:13 PM
NBrehm
Aug 5, 2015 07:57 PM
