350 rebuild
350 rebuild
Hello All,
As I have written before, I picked up a 70's model 350.Finally got around to pulling the heads.I looked at the intake and exhaust valves real closely,and found no cracks in the area at all.Valves are pretty black with carbon and oil.
Looked at the cylinder walls, and they felt very smooth.I was pretty surprised due to the age of the engine.My question is, do I need to have a hone job on these walls due to there is no damage done to the cylinder walls.
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: 350 rebuild
A hone job? Absolutely if you are rebuilding it. Honing the cylinder walls allows the new rings to seal properly.
If you are thinking of boring the cylinders, that is used to correct flaws in the walls such as grooves/gouges, tapering, and ovalling(not being perfectly round from top to bottom). With the exception of grooves and gouges in the walls, you cannot tell if a cylinder needs to be bored or not be feel.
Magman
Sep 13, 2015 08:43 AM
Eric-86sc
Aug 24, 2015 09:01 PM
