350 Long Block
Old Mar 9, 2011 | 11:38 AM
kazamh13's Avatar
Car: 1987 Camaro Z28
Engine: 5.0 TPI
350 Long Block
will a 350 long block fit on my 86 Camaro SC?
Thanks!!!
Old Mar 9, 2011 | 11:46 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 350 Long Block
Yes. 350 is 350. Long block usually means comes with heads, maybe intake. Short block usually means no heads. You'll have to talk to seller to determine exactly what parts he is selling, as everyone says different things.
Old Mar 9, 2011 | 02:47 PM
kazamh13's Avatar
Engine: 5.0 TPI
Re: 350 Long Block
Thanks dude... i was talking to him and he told me it was a 350 long block used in a Pontiac GTO but i will ask him more about it... thanks for your answer...
Old Mar 9, 2011 | 02:54 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Uh, a GTO 350 is either a old Pontiac engine (although I'm not sure they put Pontiac 350's in GTO's), or an LS1.
Unless an older GTO had a 350 small block Chevy swapped into it.
Make sure you know what you're getting. Post a pic here if possible.
Old Mar 9, 2011 | 04:58 PM
kazamh13's Avatar
Engine: 5.0 TPI
Re: 350 Long Block
Yes the GTO get the 350 in a swap for the stock engine... i will ask for pics and i ll post some tomorrow
now the engine is been restored... thanks....
Old Mar 10, 2011 | 08:23 AM
torque_is_good's Avatar
Re: 350 Long Block
I can't really comprehend the message above however, check the valve cover to valve cover width and on which side the starter is located
Old Mar 10, 2011 | 01:10 PM
chevyv8guy's Avatar
Car: 84 firebird
Engine: 355
Transmission: 700r4 stage 2 shift kit 2500 stall
Re: 350 Long Block
What year is the GTO it could be a 350 big block or an ls1 like five7kid said ...that will not fit right in..gonna have to make some changes if its a chevy 350 or an ls1..then yes it will drop right in except the ls1..again some changes will have to be made
Jake_92RS
Jan 28, 2020 10:37 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
MoJoe
Sep 24, 2015 09:12 PM
fbirdroller
Sep 2, 2015 10:27 PM
