305 tpi to 350 carb tranny kick down cable.
Old Mar 15, 2011 | 06:47 PM
defaria27's Avatar
Car: 1992 Camaro Z28
Axle/Gears: factory 373
hey guys i have a silly question....
I went to A 350 carb from a 305 tpi...i took out the ecu and harness, but the tranny kick down was hooked up in the front of the engine before, now the carb is alot closer to fire wall.
My question is does anyone know what tranny kick down to use, i hooked mine up as is, but i have to pump the gas to get it to kick down because its way to long....
so do i just take this one out put a shorter one in? i have NO idea how to adjust one...please let me know what one to purchase.
-Matt
Old Mar 15, 2011 | 08:28 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 305 tpi to 350 carb tranny kick down cable.
Cable length has nothing to do with it,
You must have the correct leverage in relation to the % throttle opening ( as the stock TB did ) otherwise you will burn up the trans
Need a TV corrector cable to suit your carb to get the leverage right
http://www.summitracing.com/search/T...d=tv+corrector
and most likely a custom or homemade bracket for the TV cable outer
There are aftermarket brackets for carbs that have both accel and TV cable mounts
http://www.jegs.com/i/JEGS+Performan...15150/10002/-1
http://www.jegs.com/i/JEGS-Performan...15229/10002/-1
Old Mar 15, 2011 | 09:32 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I've always read of everyone swapping out for a TBI or carbed cable rather than the TPI cable because of it's length and it being hard to deal with. If it were me, I'd swap for a TBI cable - my car was TBI and my stock cable worked great.
Old Mar 15, 2011 | 10:34 PM
defaria27's Avatar
ok i cant find on summit a kick down cable for TBI, but i found some " universal ones" i think, but how do i measure lenght. i was looking to just buy one and put it in? i guess theres some adjusting to do?
Old Mar 16, 2011 | 12:02 AM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Get one from an autozone for either a carb'd third gen or TBI one.
Old Mar 16, 2011 | 03:01 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Not likely to find it at Zoned Auto, although they may be able to order it from the dealer.
As stated, carb'd or TBI will work. I have a used carb'd one I'm not going to need if you're interested.
Old Mar 16, 2011 | 03:27 PM
Car: 1992 RS
Engine: Carbed 350
Call TCI - find out the length of theirs:
http://www.compperformancegroupstore...lesAccessories
Or dealer.
Old Mar 16, 2011 | 03:28 PM
http://www.autozone.com/autozone/par...mString=search
None of these will work?
Old Mar 16, 2011 | 03:39 PM
five7kid's Avatar
Originally Posted by bradley23150
Wow. Good find. Learn something new every day. Didn't know Pioneer was making them.
By the way, it's a "throttle valve" cable, not "kick down" or "detent".
Old Apr 3, 2011 | 03:10 AM
64elko's Avatar
Car: 64 elcamino
IN NEED OF MORE INFO !
hello
ok so i am taking off my tpi and going to a carb,,,,i have a 350 with a 700r4,, 1986 motor and trans.... 1. so what tav cable do i use from zoned auto 2. what tav bracket do i use to bolt to the manifold , ( a good one ) OK NOW HERE IS THE BIG QUESTION,,,, #3. SINCE I HAVE AN ecm CONTROLED 700R4 .. DO I HAVE TO BYE THE VACUM KIT TO PUT ON MY 700R4 LIKE TCI SAYES YOU NEED WHEN DOING THE SWAP ! NOW on www.CHEVYBOWTIE.com site there is a tech artical to wire the overdrive into the break pedal switch to take the trans out of over drive,,,,,
Old Apr 3, 2011 | 10:59 AM
Car: 1992 RS
Engine: Carbed 350
1) TV cable for a TBI or carb car
2) bracket your choice, something sturdy
3) Your not trying to go into/out of overdrive, your trying to get torque converter to lock and unlock. ECM controls this - going to carb means no ECM function, thus no torque converter lockup. There's a tech article at top of carb forum about TCC lockup
You also need a geometry corrector for the carb linkage - summit $21
Old Apr 3, 2011 | 12:06 PM
64elko's Avatar
Car: 64 elcamino
hello
do you know the part number for the summit part .... just trying to get eveything i need befor i do the swap....
BlueIroc-Z
Jun 9, 2019 03:22 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
