2.8 to 350 carb. need help
Old Apr 20, 2011 | 11:42 PM
firejuggalo's Avatar
Car: 1987 camaro
Hello everyone I have a 87 camaro.it had a 2.8 5 speed in it.we have replaced it with a older model 350.I seem to have a little problem my after my build we drove the car to the muffler shop and few places for a few days.upon taking the car home it died.no idea why my first guess was no gas or lack of fire.after about 20 min its started right up.the reason I'm asking it this car is my daily driver or will be I'm a little concerned.I replaced the key switch in the car when I bought it it was not a vats key setup.witch the car did have before.my mechanic told me that's the problem.I'm pretty sure from what I have read that the car would not start at all.I'm confused.the car has no ecm btw.any feed back would be greatly appreciated.so shoot me some ideas.
Old Apr 21, 2011 | 06:50 AM
NathanLewis's Avatar
Car: 85 camaro z28
Engine: 355
Transmission: t-5
Re: 2.8 to 350 carb. need help
did it even turn over, when it died?
Old Apr 21, 2011 | 09:27 AM
Car: 1987 camaro
Yes it did.it would turn over.it sounded like it was trying to start but got nothing.lol
Old Apr 21, 2011 | 09:42 AM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
What fuel pump are you using? Do you have a pressure gauge? I just did this swap and i had to bypass the intank pump and run it on a switch to keep it on. You didnt disconnect the computer under your passenger side dash did ya?
Old Apr 21, 2011 | 10:12 AM
Car: 1987 camaro
The person that hooked it up actually has the in tank and a man. On the engine.the build looks a little choppy.they just kinda did there own thing.I'm not sure about the computer is was just told it was not used.
Old Apr 21, 2011 | 10:23 AM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
So trees a mechanical pump bolted to the block and the electric pump in tank? Can u hear the intank pump turn on? Before something bad hppens I would buy a fuel pressure gauge and see what your psi is at. Should be around 6.5-7 psi
Old Apr 21, 2011 | 11:19 AM
Car: 1987 camaro
The pump in the tank is on a togle switch.I've never drove the car with it on.but it dose work if u turn on the switch.I just want to say thank u.this forums awsome I've been using it for years very helpful.
Old Apr 21, 2011 | 01:58 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
if you still have the intank pump you need to use it, the mech pump will suck enough fuel for the car to start, but it will starve for fuel. running a mechanical pump with the intank is an alternative to running a regulator. some of the older carbed cars came from the factory like this.
Old Apr 21, 2011 | 02:00 PM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
Hence why I said buy a fuel pressure gauge. Atleast its a start if your running out or not.
Old Apr 21, 2011 | 03:52 PM
Car: 1987 camaro
Sweet thanks ill start there.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
snakeshooter
Sep 7, 2015 11:13 AM
rjcme
Sep 5, 2015 01:23 PM
Formula_88AE
Sep 3, 2015 01:47 PM
willyjoejr
Sep 3, 2015 09:26 AM
