Opinions
Old May 7, 2011 | 12:03 PM
BrandonSB's Avatar
Car: 1987 Z28 Camaro
Engine: 30Slow
Opinions
looking to buy a short block assembly such as
http://www.racingjunk.com/category/9...rt-Block-.html
(all forged parts for boost^^)
afr eliminator 195 heads
edelbrock performer rpm intake
holley street avenger carb
supercomp headers
any other opinions on combos?
Old May 7, 2011 | 12:19 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Opinions
I wouldn't want to put those parts under boost.
Old May 7, 2011 | 12:20 PM
blackbmagic's Avatar
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
Re: Opinions
Get a used block. Send it to a machine shop. When you get it back it should look almost brand new and a lot cheaper than buying a brand new block from gm. Same power.
Good combo, What about a cam? If your boosting it I would stay away from the performer intake. Go with something like a victor, Or super victor. Something high flow and single plane.
If you are getting all new valvetrain, stay solid roller. Period.
What kind of boost are you planning for turbo, procharged, roots?
Old May 7, 2011 | 12:52 PM
BrandonSB's Avatar
Engine: 30Slow
Re: Opinions
Turbo, any suggestion on parts?
Old May 7, 2011 | 01:10 PM
Car: 1985 IROC-Z
Engine: 355
Re: Opinions
How in the hell do u plan on using hooker super comp headers with a turbo? Id like to know.
Old May 7, 2011 | 05:50 PM
BrandonSB's Avatar
Engine: 30Slow
Re: Opinions
well i just want the bottom end to be able to support turbo for the future, imma see what i can get out of it NA first.
Old May 7, 2011 | 06:32 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Opinions
A better idea is to build a NA bottom end, and then build a forced induction one when you're ready.
Old May 7, 2011 | 06:50 PM
Car: 1985 IROC-Z
Engine: 355
Re: Opinions
You do realize those are two separate directions. You cant just build and then add a turbo. You can make no power waiting for your turbo setup, or you can make good power but then cant turbo.
You want an opinion stick to one route.
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
cheesehomer
Dec 31, 2015 08:48 AM
skinny z
Oct 5, 2015 06:23 PM
Jlanz55
Sep 29, 2015 08:55 AM
