A/C & air pump bracket
Car: 1983 Z28
I am not going to use an air pump. Has anyone cut off the portion of the bracket that houses the air pump? Or should I just get an air pump delete pulley?
Car: 1987 Trans Am
Engine: LQ9/L92
Re: A/C & air pump bracket
if you've got the full serpentine setup, just pull the pump and bypass it, pulley not needed, replacement belt:
https://www.thirdgen.org/serpentine
Car: 1983 Z28
Could I cut the bracket under the a/c compressor since I won't be running the pump? I don't like the look of the empty bracket sticking out and taking up space.
evilstuie
Jan 9, 2020 08:29 PM
ambainb
Apr 25, 2016 09:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
mcquigg
Aug 13, 2015 02:26 PM
db057
Aug 11, 2015 10:11 PM
