possible 305 to 350 problems?
Old Jul 25, 2011 | 10:56 AM
musclecarguy91's Avatar
Car: 91 Camaro Z28
Transmission: auto
I have a 91 Z28 with the 700r4 trans. I'm doing the typical 305 to 350 swap. I just got the 350 back completely rebuilt. I'm not sure if these questions fit in this section so I apologize if they don't. I have a 80's truck 350 and the camaro has the vortec engine. Will the cerpantine set up bolt up to the motor? or will I need different brackets or just forgo the whole cerpantine set up? Another question I have is: how much controller does the computer have over the automatic transmission? And my last is: Is the fuel pump in the gas tank? The mechanic we go to said that it is?
Any help would be great. Thanks
Old Jul 25, 2011 | 11:34 AM
Guest
Guest
Posts: n/a
Re: possible 305 to 350 problems?
The whole serpentine setup will bolt right up to the 350.
The computer controls the torque converter lockup, a 4-wire connector on the driver's side.
If you're wanting to remove the computer, there are lockup kits available.
The fuel pump is in the tank. If you had the TPI, then you gotta change the pump to a much-lower-pressure TBI-style fuel pump, then add a bypass-style pressure regulator. If you had the TBI, then ayou just need the bypass style pressure regulator to use a carburetor.
The question many of us will have for you: Why go carbureted instead of keeping the EFI?
Also, having a 700R-4 behind your 305 means that you had the worst of the V8 exhaust systems. The small 1.875" exhaust manifolds, and a single 2.25" exhaust. Your 350 will want something better. Preferably headers and a 3" exhaust.
And you probably had the 2.73:1 axle. Think about changing that, too.
Old Jul 25, 2011 | 12:45 PM
Car: 91 Camaro Z28
Transmission: auto
Yeah it is TPI and I have the carb bought already, but it was under my understanding that the whole TPI set up won't fit the 350 with the 350 heads?
Old Jul 25, 2011 | 12:49 PM
Car: 91 Camaro Z28
Transmission: auto
I assume you can get all that stuff from summit?
Old Jul 25, 2011 | 01:26 PM
Guest
Guest
Posts: n/a
I'd keep the TPI. What cam is in the 350? That may need to be changed.
If the heads on the 350 are pre '87, then you need to change the lower intake manifold, "base" to an '85-'86 305 or '85-'91 'vette version.
All the rest of the TPI stuff will work with just a custom chip, unless you're making more HP than the 305 injectors can support at a 100% duty cycle with extra pressure.
If you must go carbureted, then the pump and regulator can both be ordered from Summit.
Short term, the cost is about the same either way, if you add in the cost of the new carb. I'd return it for a full refund.
Long term, the TPI will pay for itself just in MPG. Plus the improved driveability is wonderful.
Old Jul 25, 2011 | 01:53 PM
Car: 91 Camaro Z28
Transmission: auto
not quite sure of the exact came specs of the came. I believe it has like 495 or 5 something lift. And the heads are from like a 86 to 94 truck or 84 to 96. I know if was carbed when I took it apart.
Old Jul 25, 2011 | 01:56 PM
Car: 91 Camaro Z28
Transmission: auto
So as long as I put that regulator on I won't need to drop the gas tank?
Old Jul 25, 2011 | 07:57 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
www.thirdgen.com/carbswap answers some of this
Old Aug 26, 2011 | 07:06 AM
allgood's Avatar
Car: 92 WS6 Trans am convertible
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
i did a 305tpi to 350tpi swap what all do i need to change to complete the swap
jhawkeye
May 25, 2022 06:33 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Reborn756
Sep 4, 2015 03:42 AM
st.evel07
Aug 13, 2015 06:15 PM
