bbc swap burning plug wires
Car: 1983 camaro with88nose ground effec
Engine: 468bb
Transmission: 700r
Axle/Gears: 323 posi
have hooker swap headers and cheap accel wires with 90 degree boots would 115 degree boots work better
Guest
Posts: n/a
Re: bbc swap burning plug wires
I had success with these when I was burning wires on headers: http://www.summitracing.com/parts/TRD-8815/?rtype=10
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I've used straight boots on all my BBC engines. The only time a BBC needs 90* boots is if the plug wires run under the headers. That's very unlikely for a production car.
I currently use sleeves similar to the ones in that link just for a little more protection through the tubes.
Car: 71' Chevelle
Engine: 496ci 675HP Streetable!
Transmission: TH400 3500 Stall 9.5" Converter
AlkyIroc is totally correct...should have a straight or slight bend to them (some allow you to bend a bit to fit). Also the taylor boot holders work well, but if you want a cleaner look I personally run the MSD Boot guards. I run this on my BBC and hav ethe wire laying on the header...doesnt phase the guard at all.
http://www.summitracing.com/parts/MSD-3412/
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
