Oil pan trouble
Old Aug 16, 2011 | 07:13 PM
Seven_MPG's Avatar
Car: 1985 Z28
Engine: '69 350 4 Bolt Main .30 Over
Transmission: 700r4/B&M Shift Kit and Flywheel
Axle/Gears: GM 10 Bolt 3.23 Gears
Oil pan trouble
I did a test fit the other day with the engine on the hoist.69' Gen 1 sbc going into my '85 Z28.The problem is I bought a pan off ebay and it is a little too deep,when I did the test fit it wouldn't clear the k-member.It's a finned aluminum pan so I can't pursued it in.
Now for my question.
I need a stock replacement pan for my engine.1969 350 5.7,two piece rear with drivers side dipstick.I'm hesitant on buying one only to put it on and hit the k-member again.Anyone know one that will for sure fit on my block and not hit?
Any help would be awesome
Old Aug 17, 2011 | 03:36 PM
Guest
Guest
Posts: n/a
Re: Oil pan trouble
Get a pan that fits a '71-'78 Camaro 350.
Old Aug 17, 2011 | 03:46 PM
Seven_MPG's Avatar
Car: 1985 Z28
Re: Oil pan trouble
Awesome,Thanks alot.
Old Aug 17, 2011 | 06:22 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: Oil pan trouble
I bought this pan for my build:
http://www.summitracing.com/parts/SUM-G3531/
I haven't gotten it all together/installed yet so I am hoping for the best. Though it is a standard oil pan that looks exactly like the 71 camaro pan so I don't think there will be any problems.
Old Aug 21, 2011 | 12:35 PM
85_ZED28's Avatar
Car: '85 Z28
Re: Oil pan trouble
n/m
BDR
Nov 7, 2015 03:05 PM
abray1
Sep 14, 2015 08:18 AM
timonator
Sep 13, 2015 11:49 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
