305 to 350
Old Sep 5, 2011 | 05:42 AM
89camarojoeb's Avatar
Car: 89 camaro
Engine: 305 tbi
Transmission: auto stock
Axle/Gears: stock
305 to 350
what will i have to do to my 89 camaro before i can swap motors
Old Sep 5, 2011 | 10:11 AM
Angelini's Avatar
Re: 305 to 350
Wouldn't you just be able to swap the engine right in? Maybe get larger injectors to run the 350 vs a 305 if you plan on running TBI? The computer might not run the 350 completely right, but it should run it, its not that big of a change I don't think if you plan on keeping the TBI. Considered doing this if I ever replace the 4.3L in my S10 to a 305 or 350...
Old Sep 5, 2011 | 12:05 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 305 to 350
1) - there's a hundred threads on this, and the search function works great
The basics ...
350 injectors, chip from a 350 car (caprice), 350 knock sensor, (assuming you are keeping TBI setup), and ....
2 months to make it all happen - everyone wants to swap motors on a daily driver, then they all complain because they didn't finish in a weekend. You can't do it in a weekend, or even a week - you need time.
Old Sep 5, 2011 | 07:47 PM
Car: 89 camaro
Engine: 305 tbi
Axle/Gears: stock
Re: 305 to 350
some guy told me i have to get upgrade trannys cause the 350 will break the tranny cause of so much power
Old Sep 6, 2011 | 01:59 PM
wrath112's Avatar
Re: 305 to 350
The basics ...
I did mine in 3 nights. About 6hours at a time each night. on the 3rd night i drove it around the block.
Old Sep 6, 2011 | 04:36 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
He is incorrect, whoever he is.
Old Sep 7, 2011 | 04:01 AM
Car: 89 camaro
Engine: 305 tbi
Axle/Gears: stock
Re: 305 to 350
OK so will the stock tranny break if i put the 350 on and floor it lol
Old Sep 7, 2011 | 07:54 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: 305 to 350
Not the stock auto. A lot of people run the 700R4 behind 350s
Old Sep 7, 2011 | 08:21 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 305 to 350
Maybe... but it might break with the stock 305 too.
Old Sep 7, 2011 | 07:09 PM
Car: 1992 RS
Engine: Carbed 350
Re: 305 to 350
However, it is quite possible that the new added torque/power of the 350 motor will make the old tranny slip almost immediately. This happened to me - my tranny worked perfectly (as best as I could tell) behind the stock 305 - but the instant the 350 went in, it slipped, and I had to get a rebuild.
Old Sep 8, 2011 | 11:58 AM
five7kid's Avatar
"Rebuild" is not the same as "upgrade". "Slip" is not the same as "break".
Old Sep 9, 2011 | 04:57 AM
Car: 89 camaro
Engine: 305 tbi
Axle/Gears: stock
Re: 305 to 350
ok how much does a tranny rebuild kit cost... sorry im new to workin on cars lol
Old Sep 9, 2011 | 06:02 AM
midias's Avatar
Re: 305 to 350
Not to much a couple hundred but rebuilding an auto tranny is not that easy
Old Sep 9, 2011 | 12:22 PM
Car: 89 camaro
Engine: 305 tbi
Axle/Gears: stock
Re: 305 to 350
so do yall think it will slip or break my tranny
Old Sep 9, 2011 | 02:53 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: 305 to 350
Absolutely no way of knowing.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
